Old 02-12-2023, 12:28 PM
15bhardwick 15bhardwick is offline
Default HR Parts Anti sway bar
Anyone out there with a HR parts anti sway bar on a 64-67 a body? The area on the crossmember that the tabs for the heims bolt/weld to is not flat at all. Any pictures would be great and info on what modifying you had to do to the crossmember if any.
Old 02-12-2023, 02:27 PM
Scott65's Avatar
Scott65 Scott65 is offline
Here's a shot on my '65. Due to the nature of the spherical bearings, as long as the mount is secure, the bearings will handle imperfections in the angles. Just try to get the alignment close to straight in line with the bar end.
Old 02-12-2023, 02:49 PM
Thanks for the picture. Your frame looks a lot straighter and flat compared to a 67. I wouldn’t think that there would be a difference in frames. When I fit the piece that bolts to the crossmember there are spaces with 3/8” gap. Try to hammer and dolly this or fill it in with weld?
Old 02-12-2023, 03:26 PM
Scott65's Avatar
I would probably try to shim it with washers. As long as it's securely mounted, the aesthetics aren't really important.
Old 02-16-2023, 09:53 PM
mchell's Avatar
mchell mchell is offline
Shot of mine…71 gto. It wasn’t particularly flat as I remember, but I was able to mount it..
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
