Old 02-06-2024, 08:19 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Default Little Freezeplugs on SM heads?
Those dinky little freezeplugs, are you all just knocking them out and raplacing them with a 3/8npt plug?
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
Old 02-06-2024, 08:37 PM
mysticmissle's Avatar
That would def be an upgrade we have a set with a couple thousand miles On them and so
Far no issues these were out of the box installed
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
The Following User Says Thank You to mysticmissle For This Useful Post:
Old 02-07-2024, 01:59 PM
Johnny406's Avatar
Here's what I did, came out pretty good. I had to slightly expand the hole to start the tap. I'll threadlock them in after a good cleaning.
Old 02-07-2024, 04:21 PM
Dragncar Dragncar is offline
You might want to get a Allen head style plug.
Old 02-07-2024, 04:25 PM
Anything but an iron pipe plug, I’d never use iron.
Old 02-07-2024, 04:39 PM
Johnny406's Avatar
These are stainless steel, think they will be okay? Otherwise I'll pick up some brass ones.
Old 02-07-2024, 04:52 PM
Stainless is great.
Old 02-07-2024, 07:41 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Those also have me worried about popping out and milk shaking the motor. But figure Pontiac used plugs in the main oil galleries that would be more catastrophic if they come out!
SM has two plugs like those in their Air Gap SBC intake valley cover in the middle.
Skip Fix
