Stan PS - OK found my Super Flow 600 manual. It lists range 3 as 150 CFM so 63% would be 94.5 CFM.
Stan Weiss/World Wide Enterprises Offering Performance Software Since 1987 http://www.magneticlynx.com/carfor/carfor.htm David Vizard & Stan Weiss' IOP / Flow / Induction Optimization - Cam Selection Software http://www.magneticlynx.com/DV Download FREE 14 Trial IOP / Flow Software http://www.magneticlynx.com/DV/Flow_..._Day_Trial.php Pontiac Pump Gas List http://www.magneticlynx.com/carfor/pont_gas.htm Using PMD Block and Heads List http://www.magneticlynx.com/carfor/pont_pmd.htm Last edited by Stan Weiss; 04-19-2021 at 08:56 PM. |
So how does that relate to my flow numbers? Are you saying that the flow at .100" lift is 63 CFM, and not the 94.5 CFM shown on my chart? Is it a conversion, ie like 20 Hg versus 28 Hg? |
I have no idea what model Super Flow flow bench he used, if he used a Super Flow flow bench. Check my post which I edited after you quoted it. Stan
Those benches are calibrated to 25" so I can only assume by that big number at.100" that he was testing at 28" which is fine, but that's one of the most important things to have noted on any flow sheet you handed!
To convert flow @ 25" to 28" you X by 1.06, this leads you to see that he could not have possiblely run the flow test at 25"because that rounded off 94 cfm number would then be 99 cfm.
A few head from my list.
Pontiac 6X-4 Ported Iron 2.11 0.10000 - 89 0.20000 - 143 0.30000 - 165 0.40000 - 222 0.50000 - 238 0.60000 - 244 1.66 0.10000 - 48 0.20000 - 90 0.30000 - 122 0.40000 - 146 0.50000 - 156 0.60000 - 163 Pontiac 6X HPP Iron 2.11 0.10000 - 88 0.20000 - 153 0.30000 - 206 0.40000 - 221 0.50000 - 232 1.77 0.10000 - 85 0.20000 - 122 0.30000 - 164 0.40000 - 185 0.50000 - 196 Pontiac 455 HO '71 197 Flowtech - Steven Magnotti 3 Angle VJ Cut SF110 Iron 2.11 0.10000 - 88 0.20000 - 160 0.30000 - 199 0.40000 - 219 0.50000 - 234 0.55000 - 240 0.60000 - 241 0.65000 - 243 Pontiac 62 Ported Paul Carter Iron 2.11 0.10000 - 86 0.20000 - 148 0.30000 - 188 0.40000 - 240 0.50000 - 255 Stan
Stan those HPP numbers for the 6X head exh itted with a 1.77” valve are really quite high, like something was not set right or something, or the seat or stem was leaking and or had no valve seal on it.
I have never seen 85 cfm @ .100” out of other brand heads even when they used a 1.81” valve, and maybe also even with a 1.88” valve , but I would have to dig out my BBC notes to confirm that,.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 04-20-2021 at 06:10 PM. |
Pushrod bulge is the Flow-Choke in both CSA minimum and turbulence generation. I think.
Not by a long stretch!
In terms of a 6X head the port circumference of the 1,60” throat of the valve bowl is 5.02”, the port circumference at the push rod bulge is 5.337” , so the throat is the minimum port area with the circumference at the crown of the short turn a close second!
. Thanks for your updated reply. I plan on going to the shop in the next couple weeks to check things out and see what all is done and the equipment. I will do some inquiring on the head flow numbers and hopefully learn a little. I only did the flow testing just to satisfy my own curiosity. I usually do basic port work on any performance engine I have assembled and can't say I have assembled a bunch of them, but have done this on Chevy small blocks, my brothers Mopar small block, and my Pontiacs. First time I ever went to the extent I did on these heads. Never had any issues, and the engines always pulled hard, but these were street cars as opposed to a race/track car which would be more critical in attempting to get all the HP you can. I plan on a small shot of nitrous, just because, so that'll give me a small boost in power added to a hopeful 400-425HP build. Once I get the scoop on flowing heads from the shop that did them, I will post what I am told on my heads. |
The HPP numbers came from High Performance Pontiac Magazine. Maybe someone has some old issues and can see if they have the magazine where those numbers came from. Stan
I think it would also be important to know what the calibration is with regards to the CFM the flow bench uses. I have seen the articles, "Build Your Own Flow Bench" using vacuum cleaners, but I would think you still need to know what kind of CFM's even those units would pull? The same shop has an engine dyno and the guy I work with said it is set to be 20HP low - which they are aware of, and how they run their engines. He was not sure why, only that his grandfather who started the shop/business set it up that way. My thinking is that most dyno's use an electric motor to run the water pump and if you had the basic fan/belts (maybe an Alt.) that these would consume that 20 HP needed to operate them. Another question I'll ask. |
I don’t mean to say that a bench calibrated for 25 will not be accurate at 28”, it’s just that you have to know what test pressure the test was done at to compare Apples to Apples so to speak.
Stan, over the weekend I will see if I have that issue of HPP for you.
I believe those flow numbers came from this article .
https://www.hotrod.com/articles/0501...-dyno-results/ Glenn |
I have quite a few flow sheets saved from over the years if anyone wants to see some of the iron ones.
Didnt read this thread. Pushrod bulge zone is the least CSA, and provides a shock surface. Was the pushrod buldge taken down?
Pushrod bulge was not modified. What is CSA?
#38
#39
Hi Stan! I found that HPP issue you got those 6X flow numbers from.
It was in the Jan 2005 issue in which bowl ported and cleaned up 6X heads fitted with a 1.77” exh valve and a 3 angle valve job ( from what they state ) where dyno tested by Cliff against KRE’s new D port heads. The exh numbers you took from the article you got right, but I think the testing of the exh side of the 6X head at .100”was off by being really tested at .102, or .103”, as that’s all it would take to to get that what I call too high 85 cfm numbers. The reason I say this is not only because I have never seen a 85 cfm number like that out of any work I have done, but also due to the posted intake flow number for that 6X head at .100” of 88 cfm, only 3 cfm higher then that 85 cfm exh number. When you consider that at .100” a 2.11” valve has a curtain area of .662” and a 1.77” valve has only a curtain area of .552”, then at least to me that adds to my questioning of those numbers! Here are some flow numbers of 2 KRE high ported high port heads fitted with there stock 1.71” valve. As you can see none of them do better then 66 cfm@ .100”. The last flow sheet I will post is the stock exh flow from a Brodix big Brodie head with its stock 1.88” exh valve which makes for a curtain area at .100” of .590”, or 8 percent greater curtain area then .555”, yet there is only 61 cfm taking place. So to me, like I have stated either the valve opener for the 6X exh test was open more then .100”, or one of the 2 guys at HPP who wrote up that article transposed a number 8 whete there should have been a number 6! This is my best guess on this, but I am not saying that 85 cfm is not possible, but it certainly isn’t normal to me!
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 04-23-2021 at 07:55 AM. |
#40
Jim Hand's book lists stock 6X intake flow at 80 cfm @.100" and 81 with a Ported runner on a 15" bench converted to 28" of water. Looking at the exhaust numbers they are 52 cfm stock and 65 with a Ported runner and the larger 1.77" valve used.
