1982-1992 TA & FB parts WANTED 1993-2002 TA & FB parts WANTED is now part of the new Late Model Section of the PY Forums. Click this link to check it out. |
93-97 F-body RH rear caliper bracket GM pn 18019858
I am looking for the caliper bracket/backing plate for a 93-97 Fbody
the rear caliper brackets are the RH side caliper bracket/back plate from the 93-97 F-body GM part number is 18019858 its #5 in this diagram basically this one, but the right side and I dont care if its traction control or not http://www.classicindustries.com/fir...rts/g4646.html
www.fquick.com/Captainofiron 68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4 97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil 14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires |
What are tu trying to do.. Are you trying to put rear disc on an older car, as thats what it looks like as I can't see any of the previous post's. If so is this the best/easiests way to put rear disc on the rear of your Car. I have a 73 GTO that I'd like to switch over ( but it really doesn't need them, as it stops really great now.) But if I could put them on it I would if it was cheap enough.'
The plan is to piece the "conversion" together and from my estimates it will be way cheaper than the wilwood kit
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
I cant remember where, but a template is floating around and you can print it and verify against your hub and wheel. as for the master cylinder, pozzi has it listed on his site as well. should be a nice (and cheap) setup, way better than the 4 drums
and master can be used as a manual?
got some C6 front rotors and CTSV calipers wonder if I can make something work with those
not sure, I guess it all depends on the pressure required to operate the system, like if it has really big pistons, its probably going to be tough to use as a manual setup
I do know there is a set of the heavy iron brackets your looking for in a semi local junk yard. Kinda pricey tho.
This may or may not help you but its a start. http://www.flynbye.com/catalog/i29.html
http://www.fquick.com/garages/viewga...ewimg&id=74990 "You people have stood in my way long enough. I'm going to clown college." -Homer Simpson |
Thanks guys, I actually just picked these up.
