Old 10-25-2019, 12:29 PM
sportylemans sportylemans is offline
Default Master cylinder autopsy 71 Lemans with question
Pulled the master cylinder from my 71 Lemans today because I found it was leaking at the booster. Disassembled it and found that it didn’t have a stop screw in the front reservoir and when I pulled the secondary piston there was a small chunk out of the piston. Bore was seriously smooth, wouldn’t even need to be honed. Crazy that the brakes still worked great. It’s the original master. 5452310
Guess I just wanted to confirm that the set screw was a mandatory thing?
who knows when it disappeared, but I’ve had it since 2002. Might see if I can rebuild it if I could locate a stop screw and secondary piston.
ID:	522923   Click image for larger version
Old 10-25-2019, 03:17 PM
Cleaned the master up a lot more and found the set screw threads in the reservoir lead to nowhere. The threads lead to casting metal so, one less worry.
