Old 11-27-2019, 07:55 AM
jamaca85 jamaca85 is offline
Default cast iron intake
does anyone know who might have done this work to this intake?its a 70 intake i picked it up on ebay about a month ago. does it look like the runners have been gasket marched? was it a good deal for under 189.00 shipped?
Name:	Screenshot 2019-11-27 at 3.49.29 AM.jpg
ID:	525521   Click image for larger version
Name:	Screenshot 2019-11-27 at 3.49.13 AM.jpg
1970 firebird, 468, e heads,
Old 11-27-2019, 09:20 AM
Gary H's Avatar
Gary H Gary H is offline
Yes it looks like they opened up both the intake runners and extensively modified the plenum opening area. Make sure you check the port opening size compared to your heads intake port. The intake runners may have been opened up to RA IV size and be larger that your heads. Seems like a fair prize since it included shipping
Old 11-27-2019, 10:29 AM
steve25 steve25 is offline
Can you post up a closer shot of just one runner?
To me the Manifold looks like its gasket matched to a RA4/ 455SD gasket size from what I can see of it now.
Old 11-27-2019, 10:38 AM
389 389 is offline
I usually cut that exhaust heat area away.. Then the air can flow around the runners and keep things cooler...
Old 11-27-2019, 11:12 AM
Mark G Mark G is offline
If it was a all out performance the heat cross-over would be filled with aluminum.... 70's performance mod..lol
Old 11-27-2019, 11:43 AM
TB1's Avatar
TB1 TB1 is offline
looks like what SD performance does or someone has copied it?. I had Dave do the full meal deal on my manifold to go along with the Engine he built for me.
http://www.sdperformance.com/viewPro...productID=1727
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt
Old 11-27-2019, 08:56 PM
Half-Inch Stud's Avatar
Fill head crossover but donta fill the intake crossover.
Old 11-28-2019, 07:54 AM
Here's a reference for you.
The height of a stock D port runner is 2.05".
RA4 height is 2.180".
455 SD height is 2.20" .
Old 11-28-2019, 10:12 AM
i measured the height of the runners at 1 1/8 inch. i put it on my 455 with the HO heads. the heads were ported to the same size as the intake so it was a good match over the performer i was going to go with.....The guy i bought it from thought it came like that from the factory. Runs great. thanks for the info guys...
Old 11-28-2019, 10:30 AM
Yes that's what I meant...lol
Old 11-28-2019, 10:33 AM
lets see if this works..i already have it on the car so this is the best i can do sorry
