Old 07-23-2021, 03:56 PM
OG68 OG68 is offline
Default Do As I Say, Not As I Do
I think we all have said this to our kids or apprentices at one time or another. As a retired electrician I definitely know better and have had a few incidents over the last 50 years. But by the Grace of God I shouldn't be here.
The latest was a few days ago. While not life threatening it was a wake up call.
I was installing a pair of 6 volt batteries in my trailer. As I was tightening up the last cable connection the hand turning the ratchet and my wedding ring touched the other terminal. A nice arc took out a millimeter chunk of my ring but a second later I felt PAIN!
Over 200 amps heated up my ring where it burned into my ring and middle fingers. It was so hot that I burned the fingertips of my other hand as I was trying to get it off. Of course I was alone in the storage yard but had the presence of mind to remember I had a first aid kit behind the seat of my truck. A little first aid and I felt good enough to finish the job and go home. My fingers were blistered with some skin missing but it didn't look too bad. A few days later the fingers were swollen as the healing process toke place. (photos)
I finally decided to go to Urgent Care where the doctor said it looked good, gave me some antibiotics and said "Don't do that anymore".
It's now been six days, my fingers are really nasty looking but healing, so I'm saying...
REMOVE ALL JEWELRY FROM YOUR HANDS AND WRISTS WHEN DOING ELECTRICAL WORK!
ID:	570313   Click image for larger version
2007 Cadillac SRX
The Following 3 Users Say Thank You to OG68 For This Useful Post:
Old 07-23-2021, 04:46 PM
4zpeed's Avatar
4zpeed 4zpeed is offline
Many years ago and I'll never forget it, in the air-frame shop of the hanger, there was a picture on the wall, in that picture was a hand. Right beside the hand there was a bent up ring and next to that bent up ring was the skin of the ring finger that used to be on that hand. It was meant to make an impression and was quite efficient, to this very day.
Glad your ok,
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
Old 07-23-2021, 04:57 PM
Stuart's Avatar
Stuart Stuart is offline
That's one way to get a permanent ring tattoo...ouch.
I was disconnecting a battery when the wrench slipped, and touched both terminals at the same time; there was no harm to me, but it made a hell of an arc and blew a chunk out of one end of the wrench. They do store a lot of potential energy.
Old 07-23-2021, 05:02 PM
padgett's Avatar
padgett padgett is offline
If your vows do not allow removal, wrapping with electrical tape is a good idea.
Web Site
Old 07-23-2021, 06:16 PM
72projectbird's Avatar
I hate burns. I'd rather break bones, than deal with a burn.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 07-23-2021, 07:06 PM
Half-Inch Stud's Avatar
Aloe. Too late for aloe?
Old 07-23-2021, 07:38 PM
Thats when the wife stepped in LOL
2007 Cadillac SRX
Old 07-23-2021, 07:43 PM
fyrffytr1's Avatar
I found that doing most any kind of work can be harmful so just to be safe I quit working!
The Following User Says Thank You to fyrffytr1 For This Useful Post:
Old 07-23-2021, 08:32 PM
SRR's Avatar
SRR SRR is offline
Default Life's painful lessons.
10 minutes before closing moving a car battery onto the lower shelf of a cart and it slipped and fell on my toe. Lost the nail, hurt for a couple of days. I knew better than to put a suspended load over a body part. Doh!
― Calvin Coolidge
Old 07-23-2021, 08:54 PM
Jack Blum's Avatar
Jack Blum Jack Blum is offline
Years ago a nurse told me the most common ring burn was from early Chevy pickup trucks. The battery was right against the firewall and the positive on the left side. Burnt many a wedding ring off.
TigerEFI.com (Classic Pontiac Fuel Injection)
2004 GTO Company car, 1994 TA 25th Anv, 1971 Grand Safari Wagon, 1968 GTO EFI, 1968 GTO Stock, 1968 GTO Convertible in desperate need of restoration.
Old 07-23-2021, 11:27 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
I got the tatto do avoid that!
Unfortunly the tat didnt keep both middle fingers from getting broken.
Old 07-24-2021, 09:09 AM
FirebirdHank's Avatar
It's not just an electrical hazard. I worked in the home building / remodeling business for 50 years. there were many times that my wedding ring got snagged on framing or other things. I started taking it off everyday at work. I haven't worn it at all (or any other jewelry, not even a watch) for probably 30 years. My wife is fine with it. My first wife was fine with it as well. Actually I used the same ring for my second marriage, took it off after that day and haven't worn it since.
Old 07-24-2021, 12:12 PM
sdbob sdbob is offline
After we got married 42 yrs ago I asked the wife if she minded that I not wear my ring. I worked construction with my dad full time.I had sliced the fatty part of my ring finger lifting heavy steel without gloves! So I decided that there was to much dangerous actions like electrical work we did,soo she said ok. Now ring is to small. The wife has been very understanding.I didnt like the idea of off and on,I know I'm married to the best woman for me. I do wear gloves,eye protection,etc most of the time at 73! Been cut,broken fingers,burnt,fell 24 ft when scaffold broke- our guardian angel was looking out for us!
Old 07-24-2021, 12:18 PM
padgett's Avatar
and then there was the over the door exit sign...
Web Site
Old 07-24-2021, 01:05 PM
bird72's Avatar
bird72 bird72 is offline
Glad you will be OK! I have noticed that the more experienced the electrician, the more they like to work on stuff hot. Blue ozone smoke rules
When I was 18 in Albuquerque in 1974, I worked at a wood shop. An older guy that had worked there years and advanced to the cabinet section had 3 missing fingers, or missing ends of. Couple on one hand and one on the other. The two on one hand were not adjoining, like two incidents. He was cranky and i never asked what the heck he did, like times 3.
72 Bird
Old 07-24-2021, 03:08 PM
Originally Posted by bird72 View Post
Glad you will be OK! I have noticed that the more experienced the electrician, the more they like to work on stuff hot. Blue ozone smoke rules .
That is true. Never been afraid of working on live electrical, just respectful. The majority of my experience has been DC for transit vehicles and locomotives. While the voltage is relatively low (600-800 VDC), its the amps that will tickle your funny bone.
2007 Cadillac SRX
Old 07-24-2021, 10:27 PM
694.1 694.1 is offline
Several years ago at a car show, there was a shirtless kid messing around under his hood. He had nipple rings! I still shake my head over that one!
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 07-25-2021, 01:48 PM
george kujanski's Avatar
At work when I am working on our products, I'm sticking my hands into a machine with several close-fitting electronics boards. I need to take off any metal on my hands/arms because a slip could render a damage a board to the tune of several thousand $$.
Most of the time now now i don't wear any to avoid the off, on, off on.......
george
Old 07-25-2021, 02:32 PM
Old Goat Racer's Avatar
Yep. 40+ years ago I put my hand between the battery and the fender on my 67 GTO. No spark but instantly a Red hot finger. Melted skin.
I too have a permanent ring tattoo. My wedding band is in a jewelry box !
My watch quit working the day after I retired in 1994. Haven't worn one since.
Everybody knows somthin.
Nobody knows everything !
The Following User Says Thank You to Old Goat Racer For This Useful Post:
Old 07-25-2021, 04:29 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
That had to hurt! Positive terminal next to the fender is a bad deal! We've all had our moments!
