Old 07-20-2014, 11:11 PM
Option 382's Avatar
Option 382 Option 382 is offline
The beauty of 60sstuff is he knows originality. I am learning new stuff all the time from him.
Old 10-04-2018, 10:44 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default Tri-Power unit, 1966 WV (616)
I finally coupled the Calif. version A.I.R. Tri-Power with the “specific” smog air cleaner unit.
Very interesting breast, and complicated.
Chris.
ID:	494264   Click image for larger version
ID:	494265   Click image for larger version
ID:	494266   Click image for larger version
ID:	494267   Click image for larger version
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
Old 10-04-2018, 11:25 AM
DANTIP DANTIP is offline
Chris.
Well Done Chris!!
Old 10-04-2018, 01:17 PM
60sstuff's Avatar
Chris.
What a Goof.
I see were my mind was in that text.
I meant to say “Beast”.
Sorry.
Old 10-04-2018, 01:20 PM
What a Goof.
Sorry.
Wow, can't believe I missed that word!
Old 10-04-2018, 11:21 PM
bill ryder's Avatar
bill ryder bill ryder is online now
Hi Chris. That is a very impressive set up you have. Right down to the spark arrestor screens!!!! BUT it sure is ugly!!!!!!!!!!
"Bill"!
Old 10-08-2018, 12:12 PM
John V. John V. is offline
What a Goof.
Sorry.
I saw the goof right away, haha! Imagine my disappointment when I saw the pix! I figured all those air cleaner base hose nipples must have messed with you.
Very cool to see. Thanks for posting the pix.
Bill, I prefer to think of it as a very elegant design solution. I think it is beautiful to look at.
Chris, if this is just for display, it would be sweet if you set it up for the auto trans version with the vacuum secondaries. Nobody likes that set up but IMO it adds to the visual "interest". So many different things functioning in unison, every detail, such as the flame arrestor screens, adding to the whole.
Thanks for posting.
Old 10-08-2018, 04:59 PM
60sstuff's Avatar
Yes, the auto trans with the vacuum secondaries would offer a interesting visual display coupled with the A.I.R., but the 1966 GTO Tri-Power never came that way.
Besides, the plumbing of the “Vacuum unit” would not work with the plumbing of the “A.I.R. unit”.
Chris.
Old 10-08-2018, 05:39 PM
Chris, shows what i know about the '66. I take it A.I.R. was only needed for the Man Trans Tripower? Or was the Auto Trans Tripower unavailable in Calif? Interesting bit of '66 trivia.
Old 10-08-2018, 06:46 PM
Default 1966 A.I.R.
Intact Tri Power system
ID:	494609   Click image for larger version
Old 10-08-2018, 07:44 PM
60sstuff's Avatar
For the 1966 Tri-Power.
Both, Automatic and Manual transmission Tri-Power GTO’s were available in California.
The manual trans cars “sold new” in Ca. received the (616), A.I.R.
The automatic trans cars “sold new” in Ca. only received the (614), special air cleaners.
The key word “most” in the description shown in the 1966 Tempest Chassis shop manual.
Most, meaning 326 and 389 (manual and automatic) received the complete Smog equipment.
The ”Tri-Power Automatic” did not for all 50 states.
The one in my signature below is an example. Built and “sold new” in California.
I have never seen a specific document stating the reasoning behind this, but I assume it’s because the Automatic with the 3x2’s burned more efficiently than the Manual trans cars, therefore did not need the exhaust gases treated.
Two samples below showing the YR (Tri-Power with Automatic) with code 614.
Both cars were “sold new” in Ca.
Chris.
ID:	494616   Click image for larger version
ID:	494617   Click image for larger version
ID:	494619   Click image for larger version
Old 10-08-2018, 08:56 PM
Chris, I assume Cal required some sort of certification testing. I wonder if the Auto Trans Tripower got by because the end carbs never opened during the specified testing while the progressive mechanical linkage used on the Man Trans Tripower caused the end carbs to partially open, resulting in more HC?
Would be cool to learn what the test protocol was. If WOT was not required, I'm thinking the vac secondaries never pulled open. Perhaps the test was at some steady rpm. That would explain a difference in end carb opening between the two engines.
Since the cam was same in both, I can't think of any real difference between the two engines unless it had to do with distributor timing. Don't know if that differed.
But I think the end carb opening difference would make sense.
Old 10-09-2018, 10:18 AM
Default Interesting CA Smog Tech Letter
Letter to original owner of my '66 CA Tri Power 4-speed car. He said that the "modification" included the addition of the screens onto the carburetor inlets.
Name:	Screen Shot 2018-10-09 at 10.12.56 AM.jpg
Old 10-09-2018, 10:48 AM
60sstuff's Avatar
Dan,
Awesome document!
This letter coincides with post #13 talking about the “flame arresters”.
I hope your 66 wears these screens.
Thanks for sharing.
Chris.
Old 06-14-2020, 08:25 PM
60sstuff's Avatar
I get questions sent to me (I suppose because I own a 66 with the code 614 set up) via email, text, pm, etc. about what is OEM correct for the Air Cleaners and related plumbing on the California sold new 64-65-66 Tri-Power GTO's. I'll attempt to share what I know about this topic.
The system has at least two titles, maybe more;
PCCCVS = Positive Closed Circuit Crankcase Vent System
CPCV = Closed Positive Crankcase Vent
I am no expert but because I have always found these cars interesting, unique and rare I have researched any and all cars, plus their related components that left the plant with this system. It's a topic for me that's fun and one that is confusing to most since the factory application of code 614/K24 (64-65) and 614/616 (66) were few to begin with and most all have been altered (air cleaners, pipes, hoses, caps and clamps) over the decades so there are few remaining examples intact.
The 614 (Sales Code) and K24 (UPC Code) are the Air Cleaners Only with sealed oil fill cap. The 616 (1966 Only) was the above Air Cleaners and A.I.R. = Exhaust Smog System.
This thread was started in the 64-65 Tech section but also includes the 66 model year for obvious reasons. I'm only speaking of the Tri-Power GTO's for now.
Starting on Jan. 1, 1964 all Tempest Series models sold new in California were to be equipped at the factory with a special air cleaner system and a closed crankcase. The Tri-Power GTO's had modified air cleaner bases with the two ends being fitted with a single pipe and the center base fitted with a T pipe fitting. Two small hoses #9784235 connected the end bases to the center base on all the 64-65-66's. A black painted steel vent pipe #9776773 for (64-65) and a molded vent hose #9784820 for (66) connected the center base to the LH valve cover.
For 64-65 the LH valve cover had a small hole stamped in it to accommodate a rubber grommet #9776721 for a snug fit of the vent pipe. 1966 utilized a sealed chrome twist in oil fill cap #6421919 with a swiveled nipple for it's rubber vent hose to clamp to as the RH valve cover was blank. The "sealed oil fill caps" for 64 and 65 were on the RH valve cover. The 64 cap was the chrome AC "Top Hat" style that pushed down onto the oil fill tube. The 65 cap was a chrome flat twist in style that was stamped AC in the center.
Follow-up.
1964 GTO oil filler caps. One year only.
Caps were always on the RH side (passenger).
As already mentioned the 64 “sealed“ oil cap (614) was a small chrome AC push on style.
A much different style 64 oil filler cap was the Standard version.
This cap was also a push on chrome AC cap with a couple unique features.
There were “No” dimples around the outer rim and it had “trapezoid” bottom vents.
1965 had a completely different design.
Chris.
ID:	542436   Click image for larger version
ID:	542437   Click image for larger version
ID:	542438   Click image for larger version
ID:	542439   Click image for larger version
Old 06-14-2020, 09:03 PM
JohnnyAction JohnnyAction is offline
Smile Flame Arrestor Screens
Hello, I have a 1965 California built GTO with tri-power and option 614. Does anyone have a set of the flame arrestor screens for sale, or know a source I could contact? As always, thanks in advance for any and all help, John
Old 03-01-2024, 12:23 PM
60sstuff's Avatar
Default The 1966 #614 option
It’s been almost 10 years that this thread was started discussing the early emissions on the GTO in the state of California.
I’m going to speak more about the 1966 GTO factory equipped 3x2 BBL. with Automatic (YR) that was sold New in the state of California that required the #614 option.
For reasons unknown to me these YR cars were exempt from the A.I.R. “Smog” system.
Over the decades I have seen about a dozen ‘66 YR cars in various conditions.
I presently have folders on 8 of these cars as a new one just surfaced on an auction site.
I only know of two 1966 YR’s built with the #614 and they came out of the Fremont plant.
Below are these two cars with their POP. The codes are very interesting.
My research on several Fremont POP shows a number 4 indicates Rally I wheels which shows on both of these cars.
ID:	629625   Click image for larger version
ID:	629626   Click image for larger version
ID:	629627   Click image for larger version
ID:	629628   Click image for larger version
  #38
Old 03-01-2024, 12:27 PM
60sstuff's Avatar
The second 1966 YR built with the #614 option.
My good friend Anstein in Norway owns this loaded 3x2 Auto with the 3.90.
ID:	629630   Click image for larger version
ID:	629631   Click image for larger version
ID:	629632   Click image for larger version
ID:	629633   Click image for larger version
  #39
Old 03-01-2024, 01:06 PM
Default 1966 CA GTOs
That is consistent with the 4-speed CA Smog Protect-O-Plate info as well. Nice info. Chris!
Name:	Screen Shot 2021-07-28 at 3.03.23 PM.jpg
