Removing Wires from Bulkhead Connector
I've read that you should use a paper clip to get these connectors to release.
Didn't work for me.......... Can someone explain how to do this? (I'm trying to replace the resistor wire with a 12 guage one)
"Listen to her why-ee-eye-ine......... Listen to her why-ee-eye-ine" 1965 GTO Post Coupe, Burgundy w/Parchment, 467, Crower 60243, Rhoads V-Max, Ported 5C's, JB Roller Rockers, Original '66 Tripower, Dave's Small-body HEI, RA Exh Manifolds, 2.5" Exh X-pipe w/Super Turbo's and SS Splitters, Tremec TKO 600, 3.91 12-Bolt Posi w/bearing retainers, boxed frame, 4X Discs with hydro-boost, EPAS |
Well there a few types one side press in. Bulkhead Connector that the part on the fire wall out side your talking about?
I assume u are talkin about your 65?? I have a 64 with harness out right now and have a few out, replaced with new GM connectors supplied. Have a box of them in garage right now. send u the part number and removal method late tommorrow, as I work in the am.
Rick
64 Lemans hardtop 4spd, buckets |
Yes thats it Pontiac1976.
Thanks Lemans64.
The best easy way if the bulk in off the fire wall is needle nose pilers gently squeeze the too longer side in and ( this is on the middle part of the bulk the side of the bulk when att. you can't see) push towards wires, on what ever one you will need. I will get pic's unless the guy does first.
Thanks Pontiac1976, the pics would help.
Pontiac1976:
I think you may be speaking about the inside of the bulkhead.......... I'm needing to remove engine compartment wires from the piece that snaps off the backside of the fuse box - on the engine compartment side.
I had to do this fast not sure the pic's will show up big enough for you to read the writing if you save the pics zoom in on them you will see it I have a kids birthday to go to try to do this fast give you a better idea try to fix it late
Thanks for the pics, looks like my '65 connector is different, it has two removal bundles on the firewall side. They are held by a top and bottom plastic tab.
I'd like to see these pics better, my zooming makes them blurry. I REALLY appreciate you taking the time!
ok this is from a truck it a three piece yours should be very similar to yours.
you got a pic of yours to show. A in side shot. Then I can tell you what your looking for. GM car's and truck share a lot of stuff from the 60's to the 87 |
Connector number is 2973915 available in package of 25 at your local gm dealership. connector has 2 locks 1 on each side. push in a small metal piece the size of a hair pin, insert from pin side not wire side, and pull on wire. tried pictures but are to small to see properly. can try connector picture tommorrow if still needed. These pins fit my 64 Lemans, it has 2 white plastic housings on engine side of fuse block, ie 2 harness. should be same as yours.
These pins are also used on turn signal switch connector. They are called twin lock, as the name says, twins because mating connectors use the same terminal twisted 180* from one another. Good luck
Lemans64,
Thanks, if you look at this thread: http://216.178.81.108/forums/showthr...14#post2880214 Do you see the one you're referring to?
Looks like this tool is what's needed to remove many kinds of connectors.
(can't vouch for this supplier - just found it here first) http://www.sjdiscounttools.com/lis56500.html
Thses are mostly made bye Standard or Gates in the pic's there a few more that make them, & of course GM still has some.
Nope, none of above pictures match these connectors, I searched high and low when I was lookin, even ordered some to find out they were wrong. I will try and get picture today, how many of these do u need, i have about 20 left overs and could send ya a couple if that's all u need. I even tried some wiring harness makers but they would not sell seperately they want u to buy their harness.
Later, Rick
Two would get the job done for me.
I'll also try to take mine apart, if that works I'd send you them back! Send me a PM with your address and all the costs - I'll send you a MO. Thanks Rick
Rick, I looked for that part number on this site, lots there - but not that one......
http://www.pointe-products.com/Items...ype)+Terminals
"Listen to her why-ee-eye-ine......... Listen to her why-ee-eye-ine" 1965 GTO Post Coupe, Burgundy w/Parchment, 467, Crower 60243, Rhoads V-Max, Ported 5C's, JB Roller Rockers, Original '66 Tripower, Dave's Small-body HEI, RA Exh Manifolds, 2.5" Exh X-pipe w/Super Turbo's and SS Splitters, Tremec TKO 600, 3.91 12-Bolt Posi w/bearing retainers, boxed frame, 4X Discs with hydro-boost, EPAS Last edited by mrtonegto; 04-15-2007 at 01:35 PM. |
It's called a twin lock terminal, I took some pictures but they are not visible, too small. Most of the terminals they show in those places are for newer vehicles.
Where did you find them Lemans64?
I would like to get some of the various types also. Charles |
I got the firewall junctionblock connectors from GM your local dealership can order them. The part number is on previous post in this thread.
