relay plugs
does anyone know of a source to find some plug ends that fit your standard 4prong relay? Ive finally cleaned up alot of my wiring by putting relays on all of my xtra accessories. (fuel pump, elec fan etc) but do not like the look of bare wires with female ends just stabbing the bottom on the relays. ive tried home depot, radio shack (where i bought my relays) and pep boys elec. section. thanks
71 grand prix SJ 4280# 462 new for 2008 - 8.7:1 , 98cc 6Xs 246/209, 342 12bolt , BW S475 turbo JGS 50mm WG 56mm BOV. 600hp the easy way! |
what is a standard relay?
_ 87 l 86 _87a l85 l 30 I may have a few How many do you need. I sometimes get them from Delmar wire. |
That didn't work out as i typed it. Got a relay number?
only number i saw on the relay is 10R 02 7026-27 i thought these were standard relay layouts.
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets. 1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram. |
I've picked up dozens of relay assemblies from the junk yard, all with nice water-tight plugs, and some with slick mounting brackets or nice fuse boxes attached, for just the $1 price of admittance...
