Old 06-13-2009, 08:50 PM
8my$ 8my$ is offline
Default Hot coil
When the ignition is in the on position the coil gets super hot. Burn't one out so I thouht it was a bad coil .Replaced it but it still gets hot. Fast. Any ideas.Thanks
Old 06-13-2009, 08:56 PM
george kujanski's Avatar
What kind of ignition system do you have? A standard points ignition may very well do that, so don't leave the key in the ignition ON position without the engine running for long periods. If you need the accessories on, use the ACC position.
George
Old 06-13-2009, 09:24 PM
It,s doesn't have points any more. I heard it could burn the points but not a coil. Another expensive lesson. Thanks
Old 06-14-2009, 01:03 AM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Pay attention to the instruction with your non point system, some still require the use of a ballast resistor to limit the voltage to the coil. Can also burn out coil if no resistor is used.
64 Lemans hardtop
4spd, buckets
Old 06-14-2009, 03:43 PM
Some of the point conversion brands say don't leave the switch on without the engine running. It'll burn the conversion module/ignitor up same as a set of points.
That lesson would probably be even more expensive.
Adding to what Lemans64 said,
The original Pertronix Ignitor directions says leave resistor to coil, BUT the ignitor itself use straight switched battery voltage. Something their directions isn't real clear about.
