I guess you can be slow with good head gasket life or fast and change head gaskets every couple hundred passes.
From what im reading here all that matters is head gaskets not performance.
My ram air 5 build is not a max effort engine. Nor does it have pushrod tubes in the intake ports. I'm not much of a speculator but I'm pretty sure we will hit 1000ish na without crazy compression at 505in. Good enough for me
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
You guys once again have gone off the cliff in regards to basic question of the OPs post!
Here is all the dragncar needs to know. No matter what head he chooses he doesn't need to worry about head gaskets. No low compression engine is going to build enough cylinder pressure/heat to kill head gaskets (unless he boils the water)
Slowbird!YOUR the one that asked if the V can make the power in THIS thread!I just post my opinion!Tom
Sorry
