Old 09-17-2023, 10:43 PM
OG68 OG68 is offline
Default Under Dash A/C
68 GTO
Getting ready to pull the trigger for a Mark IV under dash A/C unit from Vintage Air.
While I have the engine, dash and seats out, I thought it would be the best time to install the components.
Anyone else running an under dash A/C?
Any interference with the manual floor shift?
Best routing of the refrigerant hoses?
Photos of the hose routing and interior?
Trying to maintain a period correct appearance so not interested in the integrated system.
2007 Cadillac SRX
Old 09-18-2023, 08:15 PM
tstroud tstroud is offline
I used classic auto air in my 69. I had the interior all out. It went in easy and works very well.
The Following User Says Thank You to tstroud For This Useful Post:
Old 09-18-2023, 10:47 PM
[QUOTE=tstroud;6455345]I used classic auto air in my 69. I had the interior all out. It went in easy and works very well. /QUOTE]
Where did you cut the firewall holes for the refrigerant lines?
2007 Cadillac SRX
Old 09-20-2023, 12:53 AM
jeff chmura jeff chmura is offline
I have the vintage air kit in my '65.
The lines are run where the stock evaporator would go...behind the passenger side fender.
I am also using the OEM control panel conversion kit.
Works like a champ....
Jeff
The Following User Says Thank You to jeff chmura For This Useful Post:
Jeff
Old 09-20-2023, 08:18 AM
In my kit the refrigerant lines go through the supplied firewall block off plate.
I thought that vintage air routed them through the kick panel opening.
Sent from my iPad using Tapatalk Pro
Old 09-24-2023, 08:10 AM
66sprint 66sprint is offline
If you want to be period correct, get a large grommet and drill a 2 1/2” hole below the heater plenum. This is for the high and low side hoses and the compressor lead.
Then drill a 3/4” hole in the lower part of the firewall for the condensation drain hose.
The Following User Says Thank You to 66sprint For This Useful Post:
Old 09-24-2023, 09:19 AM
Stuart's Avatar
Stuart Stuart is offline
The instruction manual for the Mark IV is here: https://www.vintageair.com/instructi...672001-VHY.pdf It doesn't have specific information for particular vehicles, but is still worth looking through in advance before buying.
The Following User Says Thank You to Stuart For This Useful Post:
Old 10-04-2023, 10:53 AM
locomotivebreath's Avatar
locomotivebreath locomotivebreath is offline
I ran the vintage air direct fit kit in my 68 . I had the shop that was doing the interior and such do it . Clean install , no interference with the under dash vents
When I wore a younger man's clothes
The Following User Says Thank You to locomotivebreath For This Useful Post:
