Old 08-18-2012, 08:03 AM
goatmanmitch's Avatar
goatmanmitch goatmanmitch is offline
Default Rally cage harness question
I am ready to hook up my rally gauges that were already in my car. I'm also considering replacing the wiring harness in the engine compartment. My question is do non-rally gauge harnesses have the blue wire for the oil sending unit and the green wire for the temperature sending unit? I ask this because my harness is pretty cobbled up but I do have a blue and green wire cut way back where wires come out of their respective wraps.
Mitch Kunath
Old 08-18-2012, 08:05 AM
indymanjoe's Avatar
Mine did...I have rally gauges now as well.
Old 08-18-2012, 08:30 AM
Old Goat 67's Avatar
Yes, green for temp sender & blue for oil sender is the same.
Non Rally gauge harness had the Green wire going to the Ign switch also to light the Temp light while cranking. If left connected, this grounds the Temp Gauge every time car is cranked and in short order ruins the meter movement. It must be cut.
Schematic of my wiring mods below.
Charles
Name:	Rally Guages & HEI-Engine Running.jpg
Old 08-18-2012, 08:07 PM
rcorrigan5's Avatar
rcorrigan5 rcorrigan5 is offline
Ouch! I hate to cut wires! Just extract the end of the green wire from the harness connector using a very small blade screwdriver to depress the detent. Then tape it off.
Just a personal preference.
By the way, the "green wire check circuit" knowledge has been around Pontiac for years and years. I discovered when I converted my '68 Olds 442 from idiot lights to gauges that no one really seemed to know about the green wire check circuit and the temp gauges on converted Oldsmobiles countrywide were pinning when they started their cars. Thanks to Pontiac, that knowledge is now out there for the Olds people as well!
Randy C.
