Old 10-04-2020, 10:42 PM
Rob in NH's Avatar
Rob in NH Rob in NH is offline
Default 69 Firebird makeover
I decided to give the bird a makeover to freshen it up a bit, lots of surprises after stripping it. Both quarters were replaced with skins. I'm replacing door skins and replacing the hood. The rear body panel is a bit of a mess.
Old 10-04-2020, 10:46 PM
Rob in NH's Avatar
another picture
Old 10-05-2020, 09:01 AM
1968bird 1968bird is offline
Looks like you are off to a good start. In for updates.
Old 10-06-2020, 07:30 AM
cnc's Avatar
cnc cnc is offline
What r u stripping the car with, looks like a fun project....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 10-06-2020, 08:58 AM
Looks like whoever did the quarters did a good job.
Old 10-06-2020, 05:39 PM
Rob in NH's Avatar
I'm using a sander from Eastwood, its called a contour sct sander.
The Following User Says Thank You to Rob in NH For This Useful Post:
Old 10-07-2020, 12:36 PM
n20ta2's Avatar
n20ta2 n20ta2 is offline
Welds look like they puckered the panels a little but not horrible. That could be worked some so you can use much less filler.
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
The Following User Says Thank You to n20ta2 For This Useful Post:
Old 10-07-2020, 12:51 PM
I know that I would be pretty happy with that weld seam. Just needs a skim coat...
Old 10-08-2020, 08:41 PM
Rob in NH's Avatar
I have the old door skin off, have to do a little bit of welding to the edges but its not bad, the new skin fit good from what I could see.
ID:	551084   Click image for larger version
Old 10-14-2020, 09:00 PM
Rob in NH's Avatar
New door skin fits pretty good to the rear quarter but not so good to the fender. The fender was patched up so I'll have to give that some attention.
Old 10-14-2020, 09:04 PM
Rob in NH's Avatar
fender gaps
Old 10-21-2020, 09:59 PM
Rob in NH's Avatar
I have the left door skin on and mounted the door to see how it fit, it need some help. The gap to the quarter is tight on top and wide on the bottom. Would you add to the door skin edge or slit the quarter?
Old 10-22-2020, 07:55 AM
I'm not anywhere near an expert but I would rather work the door edge than the quarter myself.
Old 10-25-2020, 06:43 PM
Rob in NH's Avatar
I decided to do the quarter, the door skin came out to nice to mess with it. I ended up cutting the quarter along the edge and rewarding it. I'm happy withe results.
Old 10-26-2020, 09:16 AM
Looks good
Old 11-11-2020, 09:30 PM
Rob in NH's Avatar
I have a question for the auto body guys here. Do you guys wash your body filler with final wash before priming? I don't but wanted to hear what you guys think. I've been doing this for a long time but thought I would ask.
Old 11-11-2020, 10:24 PM
n20ta2's Avatar
I do, I try not to touch anything with bare hands bit I still do it just to be safe.
Old 11-11-2020, 10:40 PM
Rob in NH's Avatar
how long do you let it dry, seams like it would soak up like a sponge.
Old 11-12-2020, 02:03 AM
I 'wash' with degreaser I get from the autobody supply store. Can't remember the name of it. I would think that soap and water would be ok though as long as you let it dry really well. Maybe under a heat lamp?
Old 11-12-2020, 08:49 AM
n20ta2's Avatar
It dries fairly quickly, you can see it change color then it slowly changes back. I think if you waiting 30 min then tack cloth it you would be good. It takes me that long to prep paint anyway lol
