Old 12-12-2019, 12:10 PM
mgoblue mgoblue is offline
Default 67-69 Firebird Door Trim Panel Rubber Strip
Is it possible to replace the rubber strip that runs along the top of the door trim panel? It appears it may be attached to a chrome bead that also runs along the length of the top of the door trim panel, so maybe it is some kind of assembly. Are reproductions made of this part? If so, is it easy to replace? Just to be clear, I'm not referring to the part that clips into the door outer sheet metal. The part I'm talking about is at the top of the door trim panel. Thanks!
You got the teeth of the hydra upon you.
Bang A Gong, T-Rex
