Old 06-07-2023, 08:31 PM
Bill Eveland's Avatar
Default Kre tri power intake
Looks promising, from fb. A double 4150 top qould be a nice option as well.
So we're finally close enough to release this for everybody to see. This has been a project we've been working on for over a year now. Already done some dyno testing, carb testing and working of finishing up the small bits and pieces. This is our Kauffman Trade Wind Tri-Power intake. Setup for both Holley 2300 series carbs and stock Rochesters. Goal with this intake is to get those big horsepower numbers out of your Poncho that just couldnt be done with a stock intake. Now up to 750 HP can be had. We've got these up on the web site for all pricing. I'll be showing some dyno testing results against other setups in future posts to show the performance gains.
ID:	613877   Click image for larger version
Illinois Outlaw Gassers
6.27@107
9.97@131
The Following User Says Thank You to Bill Eveland For This Useful Post:
Old 06-07-2023, 09:57 PM
Dragncar Dragncar is offline
How freaking cool. A big single plane Tri Power !
Well done. I have said it before, KRE makes the most hard core Pontiac speed parts for us.
Thanks Jeff.
The Following 3 Users Say Thank You to Dragncar For This Useful Post:
Old 06-08-2023, 08:19 AM
Looks like a capable flow inspired by the OFFYL Dual Quad design. Like the separated water crossover.
Old 06-08-2023, 08:43 AM
mgarblik mgarblik is offline
I like the bolt-on carburetor mounting plate as well. Lots of potential options there. The KRE guys come up with some interesting pieces . Look forward to some dyno results and customer reports.
The Following 5 Users Say Thank You to mgarblik For This Useful Post:
Old 06-08-2023, 10:54 AM
Old Goat Racer's Avatar
Is there a water neck to match ?
Everybody knows somthin.
Nobody knows everything !
Old 06-08-2023, 12:32 PM
http://www.krepower.com/Pontiac%20Intakes.htm
6.27@107
9.97@131
Old 06-08-2023, 01:08 PM
Kudos to the Kauffmans here.
Old 06-08-2023, 03:04 PM
61-63's Avatar
61-63 61-63 is offline
That's basically an offy 360 65> low riser intake but the bolt on top feature and separate crossover are nice.
The Following User Says Thank You to 61-63 For This Useful Post:
Old 06-08-2023, 03:16 PM
People are going to do a lot with this intake. I see a 2x4 top in its future. Maybe a throttle body EFI top for the street ?
Since Jeff has a running engine with his Hemi heads it would be wonderful to see his billet RAVs on a running engine.
Old 06-08-2023, 03:19 PM
And a water neck that clears the later non dimpled timing cover.
Old 06-09-2023, 06:17 AM
3X24SPD 3X24SPD is offline
I'll tell you what- this new piece is opening up some very interesting experimentation possibilities for me.
Once I get this installed and see what it does with my current 3 massaged Rochesters- compared to my existing Wilson extensively ported first run 66 PY intake- I'll surely be calling Jeff back to order just the top with the provisions for the 3 Holleys.
I can then pull the carbs off my 435/427 Corvette- which are dialed in tight- and throw them on this intake just for an easy back to back 30 minute comparison.
After that, I'm sure I can easily fabricate or probably even just buy something from Jeff to be able to pull the Dominator off my 454 Camaro which is also dialed in to the gnats ass tight- and see what that does 30 minutes later.
Also, FYI to all- I asked Jeff last night to verify height.
He confirmed that I will be able to retain the Ram Air Pan with the Rochesters.
1966 GTO (Red) WARPATH
455CI TriPower 4-Speed
1965 GTO (Black) TRIPOWR
464CI TriPower 4-Speed
1965 GTO (Blue) 3X24SPD
The Following User Says Thank You to 3X24SPD For This Useful Post:
Old 06-09-2023, 07:51 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
These guys are innovators, nice to see somebody putting out new stuff
Chris D
Old 06-09-2023, 12:41 PM
RA462's Avatar
RA462 RA462 is offline
It will be interesting to test this intake vs the ported Barry Grant six shooter intake I have on my 65 GTO street car. I already have High Ports heads on the 434, Howards hydraulic roller cam, FiTech EFI, 200-4R, and 3.73 gears. Should be an easy swap. The car runs high 11's at 3900 pounds.
UPS delivered this style of water crossover today. I'm going to see if it works better with the sheet metal intake I have on the 535 in my Grand Prix. The one I cut off a Victor intake is used up.
Todd Sedlmeier
Who ever thought pinewood derby cars would lead to this!
October 2004 HPP Shootout participate
http://www.highperformancepontiac.co...out/index.html
86 Grand Prix
535 High Port 8.93 @ 153
65 GTO
433 High Port 12.04 @ 113
The Following User Says Thank You to RA462 For This Useful Post:
Old 06-09-2023, 06:59 PM
ponjohn's Avatar
ponjohn ponjohn is offline
KRE made 515 / 554tq with 455 and as cast kre d-ports with this intake.
The Following User Says Thank You to ponjohn For This Useful Post:
Old 06-09-2023, 10:21 PM
I flowed a OFFY dual quad intake on a superflow 1200 flow bench.
Had some really good flow numbers.
http://forums.maxperformanceinc.com/...ockrin+tempest
"I flow tested both the P65 and the offy years ago and the P65 was lousy flowing whereas the offy had pretty decent flow. Another thing, Joe Cockrin (sp) the guy with the altered wheelbase 63 tempest years ago bolted a offy Dual quad intake on his 61 catalina and the car ran 10.0s. How bad can that intake be?? "
Some older but really good info.
The Following 3 Users Say Thank You to Tom Vaught For This Useful Post:
Old 06-16-2023, 06:13 AM
Beautiful
ID:	614278   Click image for larger version
