Old 09-27-2023, 06:34 PM
JUDGE3 JUDGE3 is offline
Default Trans cooler
High performance street car and stall converter 3.73 gear
how big and type of transmission cooler do you use? wanting to route one with nice clean AN fittings not rubber hose and band clamps.
how large a cooler do you use?
Old 09-27-2023, 06:48 PM
ta man ta man is offline
I have a B&M stacked plate with AN fittings.
Old 09-27-2023, 06:51 PM
how big? meant to add that.
Steve C. Steve C. is online now
My vote would also be the stacked plate design and avoid a typical tube & fin design.
Earl's Temp-a-Cure oil coolers are one of the better ones out there. As mentioned so does B&M.
Find somewhere to bolt it to as the through the radiator zip ties will eventually rub pinholes in the radiator tubes.
https://www.holley.com/brands/earls/...o_oil_coolers/
Old information here:
Old 09-27-2023, 07:12 PM
72projectbird's Avatar
72projectbird 72projectbird is online now
I run the biggest I can fit or find.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 09-27-2023, 07:32 PM
leeklm's Avatar
leeklm leeklm is offline
Agreed that a proper trans cooler is a good thing, but is there such thing as overkill? Wouldn't too large of a cooler not be preferred due to the time it takes to get a little heat in the trans?
I run tranny lines through an external basic tube/fin cooler bolted to a bracket in front of radiator, then run the line through the cooler on radiator tank. It seems I am able to get my trans temp up a little quicker for that first time trial run, then the cooler in radiator keeps tranny fluid a consistent ~180 deg same as coolant temp. Even after runnung deep in eliminations my trans temp has never exceeded 200 deg.
Not suggesting this is the preferred way, but so far working well for me.
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
Old 09-30-2023, 07:48 PM
I've done the same as leeklm. Ran that way on a 350 turbo for at least 30 years on same car no issues.
Old 10-02-2023, 12:10 PM
blueghoast's Avatar
great info, Thanks
GT
Old 10-02-2023, 04:40 PM
Formulas Formulas is offline
I like to run through the aux cooler first then through the radiator, if the aux makes it to cold the rad will warm it up and if the aux is to hot the rad will cool the fluid more
and if the fluid is still to hot after the aux and rad cooling then you have bigger problems about to happen like total engine compartment meltdown
