Old 12-28-2007, 03:49 PM
1966Bonneville's Avatar
1966Bonneville 1966Bonneville is offline
Default Build Sheet Location?
Assuming no one got it be4 we got the car (car is unmolested, other then from rust) where could the build sheet be located? We have the rear seats, pass seat, checked under drivers, cdoor panels off, consol out, and still no sign of a sheet. What are the chances that it was never in the car?
Old 12-28-2007, 04:56 PM
Formula 400 74's Avatar
Formula 400 74 Formula 400 74 is offline
I've never found mine yet either, but have you looked on top of the gas tank, and behind the glove compartment (under the dash)?
Greg
74 Formula 400, 4bbl, 3.08 non-posi, TH400, numbers matching, bone stock except full dual mufflers instead of transverse muffler. Replicates one I had 1975-1980. Daily driver.
Old 12-28-2007, 04:59 PM
1qikta's Avatar
1qikta 1qikta is offline
From my experience the Norwood cars tend to put it under the Driver seat and behind the rear seat between the masonite board and springs.
The Van Nuys cars tend to put it on top of the Gas Tank. Later second gens have a few behind the Glove box area.
Nothing is impossible if you break it down into possibilities. It's all a matter of "Want to".
Old 12-28-2007, 05:32 PM
2manyT/A'S's Avatar
Finding a buildsheet in a Norwood car is a pretty rare occurance.
From MY experience they only had one & it was generally behind the rear seat backrest on the pass.side.(the first time the backseat came out,somebody likely destroyed it trying to hastily remove it)
Old 12-28-2007, 08:58 PM
SD Formula's Avatar
SD Formula SD Formula is offline
I've never found one in either of my 74 Norwood Firebirds.
When removing an unreplaceable washer, the part will be heard hitting the floor and then vanish from the face of the earth!
Old 12-28-2007, 09:19 PM
form74's Avatar
form74 form74 is offline
Mine was under the rear seat drivers side, I was amazed that it was 95 % intact. Norwood built car.
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.075 @ 112.70
12.092 @ 112.43
12.128 @ 111.71
Old 12-29-2007, 06:34 PM
Well all the inter is out, all padding up, NO SHEET.
