Old 06-01-2021, 11:09 PM
Hotrodjohn71 Hotrodjohn71 is offline
Default Coil spring question
What would the consequences (good or bad) of a 326 car (non A/C) with stock 6 cylinder front coil springs)
My car has a 326 but I find the car was originally a 6 cyl car and I dont think the springs were changed and I havent driven it as of yet.
Thank you
Old 06-01-2021, 11:50 PM
JLMounce JLMounce is offline
I don’t know the difference in weight between the straight 6 and the v8.
Generally speaking when you add weight, you’ll drop the static ride height a bit and you may find that the car will tend to “float” a bit more.
On a stock car that is only cruised, it’s probably not a big deal. Especially considering these cars are terribly under-sprung as it is.
-Jason
1969 Pontiac Firebird
The Following User Says Thank You to JLMounce For This Useful Post:
Old 06-02-2021, 03:15 PM
1funride 1funride is offline
Tires may rub and hit wheel wells when driving and hitting bumps.
May also handle poorly. I dont know the weights but I suspect the 326 is heavier.
Drive it and see what happens. Springs are pretty cheap, but be sure to have the correct compressor as it can be a dangerous task.
The Following User Says Thank You to 1funride For This Useful Post:
Old 06-02-2021, 03:32 PM
RocktimusPryme's Avatar
Im going to go out on a limb and say if you suspect the springs are original they are going to be hashed no matter what they were originally rated for.
The Following User Says Thank You to RocktimusPryme For This Useful Post:
Old 06-02-2021, 03:34 PM
amcmike's Avatar
amcmike amcmike is offline
The original OHC6s were pretty heavy (similar to a SBC), but so are the all-iron Pontiac V8s (like a BBC). Unless you've lightened it with aluminum intake, al heads, tubular headers, etc. should be about 100lb difference.
As noted by others, it'll feel more floaty, have more body roll, more likely to bottom out on the bump stops, and possibly suffer tire rub. May not be an issue, but then again springs do tend to sag with age and these sound as though they may be original. Take it and and see how it responds under various conditions (bumps, rr tracks, angled driveways, etc.).
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
The Following User Says Thank You to amcmike For This Useful Post:
Old 06-02-2021, 04:22 PM
JimFB400HO JimFB400HO is offline
The 326 option, engine and "chassis items" are 168 pounds more than the 6. What all "chassis items" means, I don't know.
See: https://firstgenfirebird.org/files/1967/ama/24.pdf
The Following User Says Thank You to JimFB400HO For This Useful Post:
Old 06-03-2021, 09:41 AM
chassis items would refer to things like different standard transmission, brakes, sway bar etc variation when different engines are specified.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
