Old 06-03-2021, 12:48 PM
thefirebirdm@n's Avatar
thefirebirdm@n thefirebirdm@n is offline
Send a message via MSN to thefirebirdm@n
Default Rubber seals between core support and radiator?
Saw these in the Ames Catalog. Does anyone have these installed on their car? I am putting the front clip back on my wife's 68 convertible and don't recall any rubber seals between the core support and radiator. I can't picture how these would be installed. Could someone post a pic and point them out?
Jimmy
www.firebirdgallery.com
2002 WS6 M6 Trans Am - original owner
1973 Trans Am 455/4-speed
1971 Formula 400/400
1969 GTO 400/400 - 3rd owner
1968 Firebird Convertible 350/200R4
POCI - AAC
Old 06-03-2021, 12:53 PM
Just came across this thread by pure chance. Is this the seals in question:
https://www.firebird400ho.com/400-ac...t-rubber-seal/
Jimmy
POCI - AAC
Old 06-03-2021, 03:30 PM
JimFB400HO JimFB400HO is offline
Those fillers, plus the upper and lower medal baffles, were on 1st Gens equipped with 400s and/or AC. So, if your 350 does not have AC, it would not have had them from the factory.
Old 06-03-2021, 05:23 PM
Makes perfect sense. The numbers engine is a 350 but we've bagged and tagged it and swapped it for a 400. It was also a non-AC car being a convertible but we're adding Vintage Air so if these help improve cooling, then I'll likely add them anyway. Thanks!!
Jimmy
POCI - AAC
Old 06-03-2021, 05:33 PM
Good idea. Your adding the upper and lower metal parts too?
Old 06-03-2021, 09:17 PM
wovenweb's Avatar
wovenweb wovenweb is offline
Those lower baffles were hard to find 6-7 years ago when I needed one for my convertible.
1971 Pontiac Trans Am Cameo White
1968 Firebird 400 convertible, Verdoro Green w/black top
1970 Buick Skylark Custom convertible(driver) Fire Red
Old 06-04-2021, 09:12 AM
68tpls400 68tpls400 is offline
The only ones I have seen for sale lately have an asking price approaching $500.
I sold quite a few near perfect ones 10 years ago for $200.
Kind of like the price of original shakers...
Old 06-04-2021, 10:35 AM
It has the upper filler panels, which is what I think your referring to and a lower air dam that mounts under the chin but that's fiberglass (at least the one that came with the car is). Are there other lower metal parts I should consider? The lower baffles referred to above?
Jimmy
POCI - AAC
Old 06-04-2021, 10:45 AM
Interestingly, this car came with two left hand cocktail shakers in the front. The mounted one correctly then took the other and bent the crap out of the mounting brackets to franken-fit it to the right side. When I first took the front clip off and realized this problem, I watched ebay and searched around for a few months and could never find one.
Last month we finally started putting the car together again and on a whim I checked ebay and boom, RH side cocktail shaker right here in Tx, up in Dallas. Hit the BIN. Paid ~$300 for it with shipping.
Speaking of that, I bought these brackets from Ames as well but I don't recall seeing them on the front cocktails. Anyone have pics showing how/where these are used? I have the 69 Assembly Manual and don't think they're pictured in the drawing either.
Jimmy
POCI - AAC
Old 06-04-2021, 10:46 AM
Hey!! Have you driven your 2004R yet? I should have my car finished in the next couple of weeks to take a test drive. Not really super confident how its going to go. If not, looks like I'll beat you to it.
Jimmy
POCI - AAC
Old 06-04-2021, 10:58 AM
Those brackets mount under the front shakers for '68. If you actually have '67 shakers, I don't think you need them. All three years' front shakers are different. (many people sell them as '67-'69, which is incorrect)
Regarding the lower baffle, the crappy repops are fiberglass, and crumble the first time you hit a curb or something else under the car. OEM ones were steel like the upper x-baffles.
Oh, and a full set of four shakers used to sell for about $100 back in '06-'08 date range. Became extremely hard to find about 2012.
The Following User Says Thank You to 68tpls400 For This Useful Post:
Old 06-04-2021, 11:02 AM
I kind of figured that might be the case RE: the lower baffle. I'll keep an eye out for a steel one though with the prices you guys mentioned. Ugh. I'll post pictures of the shakers shortly. I read somewhere, and believe this to be true, that GM never stamped them with a PN which makes them hard to identify.
Jimmy
POCI - AAC
Old 06-04-2021, 12:31 PM
Here is the current set that will be installed on the car. I did notice the shape of the brackets is slightly different. If you guys know what years these are and/or if I'll need those brackets for them, please let me know.
Jimmy
POCI - AAC
Old 06-04-2021, 12:33 PM
The first pic here is the mangled LH shaker I removed from the car. I'm going to try and straighten out the brackets, clean it up and paint it to sell it. The second picture is another shaker I got from somewhere. I was planning to try to use it for the RH side until I found the one up in Dallas but I think this may be a rear shaker? Anyone know? This one will get sold too.
ID:	567676   Click image for larger version
Jimmy
POCI - AAC
Old 06-04-2021, 01:01 PM
See:
http://www.badgoat.net/CRH_homepage/...il_shakers.htm
Old 06-04-2021, 01:10 PM
I've seen that page, forgot about it. Thanks. So the LH is correct 68, the new RH is 67. As for the one I thought might be a rear, I think it is a rear but it doesn't match any of those pics. Maybe a rear for a 67 Camaro? The only difference is the shape of the bracket and no 90 degree bend on mine, like the one in the pic.
Jimmy
POCI - AAC
Old 06-04-2021, 02:21 PM
I think the oddball one is maybe a '69 front.
Definitely not a rear form any '67-'69 'bird.
I had some '69 fronts a while back, and I think they were taller than '67-'68.
