Old 06-25-2018, 09:50 PM
straycat's Avatar
straycat straycat is offline
Default 1965 Le Mans
Originally Fontaine Blue w/black. Now has 1976 400 w/T400 trans and Hurst Pro Matic II shifter, 2:56 posi rear. Edelbrock Performer intake with Holley carb. New front assembly from Moog, AMD, Rare Parts. New brakes w/finned Buick drums in front and late model alum rear. KYB gas adjust shocks. Now has steel wheels and poverty caps. 14" front 15" rear. Car needs body and paint. Asking $11,900. For some reason I cannot ad pics tonight, will try again Tuesday.
Old 06-26-2018, 12:01 PM
straycat's Avatar
Default 65 Le Mans
Some pics added more coming. Other info: front tires are 215/70R14 on 7" rims, rear tires 235/70r15 on 7" rims.
ID:	486426   Click image for larger version
ID:	486427   Click image for larger version
ID:	486428   Click image for larger version
ID:	486429   Click image for larger version
Old 06-26-2018, 12:19 PM
straycat's Avatar
Some more info and pics. Cylinder heads are 6x, carb is list 3310 Holley dual feed and 2 jet plates, vacuum secondary with electric choke. Rear window exterior trim not installed, Metro door seal and trunk seal not installed and KYB rear shocks not installed. Ames emergency brake kit not installed. Note pictures appear washed out because of sunlight. Also the car is Pa titled in my name
ID:	486431   Click image for larger version
ID:	486432   Click image for larger version
ID:	486433   Click image for larger version
ID:	486434   Click image for larger version
Old 06-27-2018, 08:25 PM
catalina_dream's Avatar
catalina_dream catalina_dream is offline
You have a PM.
1972 Firebird
462, 6X heads, RA4 cam, iron intake, Cliff's Q-Jet
3925 race weight
Best of 12.88 @ 105 so far
Old 06-28-2018, 02:07 PM
straycat's Avatar
Catalina Dream there's nothing in my messages
Old 06-28-2018, 08:04 PM
Now you do. My bad. Didn't fill out the subject line so the PM didn't send. Thanks for letting me know.
1972 Firebird
3925 race weight
Old 06-30-2018, 08:01 PM
Mike Davis's Avatar
Any rust in this car? Floor pans? Frame?
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 07-02-2018, 04:33 PM
straycat's Avatar
floors and frame good. rockers need replacement. Qtrs new but need correct reinstall. some rust in fenders and doors. This still might become my new race car. Or drive now and fix as you go.
Old 07-15-2018, 09:47 AM
straycat's Avatar
Price drop to $9,900. Deliver to Norwalk possible.
Old 07-21-2018, 09:11 AM
straycat's Avatar
Still for sale. Bringing car to Norwalk in case someone is interested. I will have title with me. It will be parked pit side, I want to make a few runs. Still have the 12 bolt available in parts section, can bring along.
