Old 10-25-2021, 06:58 AM
Jimbobeast Jimbobeast is offline
Default Quadrajet still in plastic
Can someone help with decoding this Quadrajet? I bought it for $10 about 30 years ago when Hilliard Pontiac here in Bradenton, Florida closed their doors. I can't see the stamping through the plastic wrap and I hope the box numbers will make sense to someone. Also, what do you think it's worth? I don't need it.
ID:	576085   Click image for larger version
ID:	576086   Click image for larger version
ID:	576087   Click image for larger version
Old 10-25-2021, 07:25 AM
74SDformula's Avatar
74SDformula 74SDformula is offline
Can't identify it by the part number but it appears to have a divorced choke so it would be a 1972 or earlier I believe. Might be interested in it for my 1968 Firebird once you decide on a price.
Old 10-25-2021, 08:39 AM
Replacement Carb number for a 1970 7040263 or 7040264 carb.
Old 10-25-2021, 09:22 AM
unruhjonny's Avatar
wow - what a steal of a deal you got there!!!
1970 Formula 400
Old 10-25-2021, 09:50 AM
Kenth's Avatar
Kenth Kenth is offline
Correct, 24-6010 also is a service replacement for 7040268.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 10-25-2021, 10:19 AM
burd's Avatar
burd burd is offline
Look it up in the Qjet book.
Just Say No To 8” Flakes
F ire B irds
Old 10-25-2021, 11:02 AM
padgett's Avatar
padgett padgett is offline
Even number automagic, odd number manual. 26 standard engine QJ, 27 for fun engines. See here.
I make the number on the box as 07046927 which frankly is the rong sequence 07046 says 1976 but 1975 and after should be 17056. I read 927 as a California Chevrolet stick shift
That said it does have a Pontiac inlet and choke coil on manifold so I really don't know. Have to wonder if that is the rong box.
Web Site
Old 10-25-2021, 11:07 AM
I bought another Q-jet at the same time with box but not in plastic. That carb is a 07040263, which I believe is a 1970 400 MT carb. Not sure if it also fits the RAIV which is in the car.
I also picked up 2 1970 8-track dealer install packages complete with wiring harnesses for the entire 1970 Pontiac line and the 8-track tape that tells you how to use the 8-track player. I bought those for $5 each and I still have one that is unopened (still has 1970 air in the box). I also got a 1971 cassette player dealer install package but I had to shell out 10 bucks for that baby. I sold that long ago.
Old 10-25-2021, 11:26 AM
padgett's Avatar
7040263 is a standard 400 MT, RA would get a 7040273 if a Federal car. Many have been restamped over the years.
Web Site
Old 10-25-2021, 11:33 AM
unruhjonny's Avatar
wow - right place, and right time I guess.
Good for you!
IIRC some of the later service replacement carbs (which still retained the original application number) had a zero infront of the application number - as that one would seem to be.
7040263 = 1970 400 s/t; non-California emissions
1970 Formula 400
Old 10-25-2021, 11:40 AM
I will try to see if I can read the carb stamping through the plastic. Maybe it is different from the box number?
Old 10-25-2021, 11:41 AM
Also, what is a "Federal" car?
Old 10-25-2021, 11:45 AM
padgett's Avatar
Back in the day California emissions requirements were stricter than the rest of the country (Federal) and carbs were tuned differently which resulted in a different part number.
Web Site
Old 10-25-2021, 11:46 AM
Padgett, I think I sold that 1971 cassette package either to you or Chris Casperson 25 years ago. If I recall, it was a merchandise exchange, no cash changed hands.
Old 10-25-2021, 11:52 AM
Then again, I can't remember what I had for breakfast, so all bets are off...
Old 10-25-2021, 12:13 PM
unruhjonny's Avatar
the number printed on the box will be the part number;
the number stamped on the carb is an application number.
The two numbers are different.
1970 Formula 400
Old 10-25-2021, 01:46 PM
padgett's Avatar
Hoo boy. There may be a lot of numbers on a box but since the general discovered computers 70, 070, or 170 prefix designates Rochester Carb (or Rochester Carb license made by Carter). The next four indicate the decade, year (application not when made), car line, carb type, and last two the specific application. Not complicated.
Now a box may have a lot of other numbers (10- is an ACDelco number) GRP is just location in manuals).
But a 7040273 (1970 QJ Pontiac RA with manual transmission) on the carb will also be on the box. Somewhere.
Web Site
Old 10-25-2021, 02:38 PM
Kenth's Avatar
7046927 is the SPARE PART-NUMBER found in the Pontiac MPC for the 1970 Bonneville 455 H.T.-4 BC exc. E.E.S. or H.P. Rochester Quadrajet stamped 7040262.
Also as found in the Delco/Rochester Manual #9 24-6010 as a Service Replacement for 1970 400/455 non-California All Transmissions.
There is NOTHING Chevy about this unit.
Also, a 7040273 would have 7036914 and 24-672 stamped on the Delco box, NOT 7040273. The actual application number was never stamped on the box.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 10-25-2021, 02:57 PM
OK, thanks to all for the replies. The "not in plastic" 7040263 NOS carb that has sat on a shelf since 1970. Should I rebuild it purely due to age, or try it on the car first?
Old 10-25-2021, 03:01 PM
Kenth's Avatar
I´ll have to correct myself, 7040268 should read 7040262.
And the Service Replacement for 7040268 is the Delco #24-6012, Pontiac part-#7047056.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
