Old 03-28-2015, 11:47 PM
Formulabruce's Avatar
Default 1970 Rear end Stamping question
Take a look, Its only my Guess, as I am NOT a 1970 guru like some of you are.. Thoughts? I was expecting the "E" to be on the same line as the rest.. Thanks, FB
Old 03-29-2015, 02:36 AM
A Schab A Schab is offline
That's the way all of the 12 bolt posi's are that I have here are.The E is for Eaton.
Old 03-29-2015, 06:51 AM
johnta1 johnta1 is online now
Agree.
Mar. 31, 1970 build date, on dayshift.
Does that match the car's build date?
Old 03-29-2015, 02:26 PM
165th's Avatar
165th 165th is offline
Agree.
There should be a cast date on the rear end also that should precede the build date of the assembly.
Old 03-29-2015, 05:41 PM
The Boss's Avatar
The Boss The Boss is offline
On the center section - 2 or three digits only, Julian date.
And go racin' in the street.
Old 03-29-2015, 05:49 PM
I would say the stamped date is for when the axle was assembled. (after the cast date probably)
The cast date for when it was 'cast' ().
Never checked to see what time difference there may be in them.
Old 03-29-2015, 05:54 PM
165th's Avatar
Here's the cast date for Adrian's differential case.
Cast date will precede the assembly date hammered in the axle tube.
My case has an additional number 8421 hammered in that I've never seen before.
Name:	hammered number on pumpkin case s.jpg
Old 03-29-2015, 06:55 PM
Thanks!!, Yes the Stamped on tube date preceeds the car by a few weeks.
^Thanks for the additional info on the center section stamping.. FB
Old 03-29-2015, 08:03 PM
FunctionalShaker FunctionalShaker is offline
If you look closer to the spring perch, you'll probably find a lone "D" as well.
Old 03-29-2015, 08:20 PM
Thanks, Its a bit pitted ( a NE car) but Ill look this week,
