Old 11-10-2019, 10:00 AM
Default 1970 Firebird Rear Axle Brake Backing Plates
Looking for a solid set of rear axle drum brake backing plates from a '70. Other years may be the same (?), but since my cars are '70 models that's all I have to look at
As best I can tell, the 10-bolts and 12-bolts used the same plates.
Light surface rust OK... but don't want anything with heavy pitting.
Thx.
Old 11-10-2019, 09:50 PM
yahooskidoo's Avatar
yahooskidoo yahooskidoo is offline
I have the complete drum brakes off a 79 Trans Am 10 bolt. Can get pictures if you like.
Old 11-11-2019, 09:11 PM
Scott Thelander's Avatar
Default Hello
fairly sure these are correct
dust shields
no adjuster holes
single e brake cable holes...
bolt in top stud ...
email sent
Scott
NO pitting ... very straight,,, they have never touched the garage floor ,,,
n bend s in the dust shields
I have original drums also
and delco wheel cylinders .
ID:	524280   Click image for larger version
ID:	524281   Click image for larger version
ID:	524282   Click image for larger version
Old 11-13-2019, 02:27 AM
shipped em today
thank you
very smooth transaction
Scott
The Following User Says Thank You to Scott Thelander For This Useful Post:
Old 11-13-2019, 09:13 PM
Thanks again, Scott!
Will let you know when they arrive-
