Old 07-21-2003, 05:16 PM
jcruz's Avatar
jcruz jcruz is offline
I should be receiving my front brakes lines in the next day or so. I'm starting to look through catalogs in anticipation of ordering the remaining lines and looking through them I notice that the front to rear lines can be ordered as either 1 pc or 2 pc.
Why the difference and what's preferrable?
Thanks,
John
1969 Firebird resto...doing my part to keep PY profitable....
69 Firebird/TA clone
jcruz's Avatar
Thanks,
John
Old 09-21-2019, 11:03 PM
tolerico tolerico is offline
Default Brake Lines 1969 Firebird
Bump for getting an answer on this. I too see that brake lines are sold as 1 piece or 2 piece front to rear lines.
My 1969 (factory p/b and A/C) has 2 piece front to rear lines originally ---- read on this forum that it is because "1969 Firebird A/C cars had a prop valve on the 'frame' under the driver door".
Called a Disc Brake Proportioning Hold-Off Valve. From a website: This brass valve controls the hydraulic pressure to the rear brakes to evenly distribute braking force front to rear to keep the vehicle level during braking on models with a heavy front end.
So is that why was it on A/C cars? Assume I can delete that valve and run a 1 piece front to rear brake line if desired, since I have a Wilwood adjustable proportioning valve at the master cylinder for the rear disc brakes.
Experts... ?
