Old 11-08-2019, 08:46 PM
427454 427454 is offline
Default 1973 formula hood moulding
Will a 1974 camaro hood and fender mouldings fit properly on my 73 formula hood?
Old 11-08-2019, 09:06 PM
I don't know for sure, but I would think it would not be?
The Formula hood is fiberglass, which I think is thicker than a steel hood?
Might have to check a parts book.
Old 11-08-2019, 09:50 PM
77 Canamman's Avatar
GR 8.054 MOULDING, HOOD 479085 70—76 ALL—REAR
Per 1977 parts book
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 11-08-2019, 10:28 PM
Hmmm....
Your right on the listings.
I never actually compared mine to the TA chrome.
Would have thought the Formula hood was thicker where it attached.
Old 11-09-2019, 01:26 AM
GREGGDOG GREGGDOG is offline
No definitely on the Camaro fender top trim as it is much smaller/shorter than the firebird. I'd also doubt the Camaro hood trim as a consequence. Believe it or not, the 70-81 Camaro top of door molding is up to 1/2" plus longer than a firebird. I know from personal experience.
Old 11-09-2019, 06:05 PM
Hmmm....
... prompted me to walk into my garage where I conveniently have a TA hood and Formula hood stacked adjacent on their sides.
Formula hood and TA hood are indeed the same thickness at the back. The Formula hood is only the outer skin of fiberglass at the back. The inner panel fiberglass stops about a half inch from the rear edge. The T/A hood has the outer panel metal hemmed/folded around the inner panel metal. So it's three layers of metal thick at the back. Three layers of metal appears to be about the same thickness as the one layer of fiberglass...
Old 11-09-2019, 06:41 PM
Cool! Thanks for the info.
Mine are in Illinois, too cold there to check it out.
Old 11-11-2019, 03:46 PM
tonyk tonyk is offline
Not sure I'm remembering this right, doesnt the Camaro trim have a completely different profile than the Firebird? If I recall theirs resembles the trim pieces on the fender and door top exactly where ours is a flatter design.
Old 11-14-2019, 07:54 PM
Aus78Formula Aus78Formula is offline
Are you referring to the rear hood decor strip? No, Camaro and Firebird completely different, a Firebird hood is narrower across it meaning longer fender corner pieces to meet the doors.
