SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 08-07-2022, 07:16 PM
njsteve's Avatar
njsteve njsteve is offline
Default Repro Pontiac "068" Cam (Melling SPC-7) and Lifters
Melling SPC-7 reproduction camshaft and lifter set. Reproduction of the Pontiac "068" cam.
I ran this setup in my Grandma's 1975 Firebird Esprit when I first rebuilt the original 350 enigine. After about 1,000 miles I decided to replace the 350 shortblock with a 1970 455.
Here's the original rebuild thread: http://forums.maxperformanceinc.com/...=gramma&page=4
As a result, I removed the SPC-7 camshaft and oiled it up properly for storage. I also carefully marked each lifter and placed each one in a box that was marked with its postion like "Int cyl 1" etc., in case someone wants to install the cam and the lifters which were successfully paired together.
The cam specs are as follows:
Intake Duration at 050 inch Lift: 212
Exhaust Duration at 050 inch Lift: 225
Duration at 050 inch Lift: 212 int./225 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.408 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.407 in.
Valve Lift with Factory Rocker Arm Ratio: 0.408 int./0.407 exh.
Lobe Separation (degrees):113
$95 plus shipping
Thanks, Steve at nk15268@hotmail.com
ID:	596017   Click image for larger version
ID:	596018   Click image for larger version
ID:	596019   Click image for larger version
ID:	596020   Click image for larger version
Old 08-18-2022, 07:22 PM
njsteve's Avatar
Price drop $75 plus shipping.
Old 08-20-2022, 10:00 PM
Steve Barcak's Avatar
As long as it is in good condition as you say, I will buy it if still avail. PMing you now. thanks
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 08-23-2022, 08:36 AM
njsteve's Avatar
Got the PM and we are good to go.
Old 08-28-2022, 08:43 PM
njsteve's Avatar
SOLD
Thanks PY
