#61
I do not think The original owner is remembering it incorrectly.... I think I am misunderstanding him. After reading the above, it makes sense that he was stating they were on the cars already..That infact could have been why he ordered the retractable ones..I am having lunch with him tomorrow, I will pick his brain some more..... Thank you for your post |
#62
Sloan66, it isn't entirely understood, but it has nothing to do with the Zone.
It is related to the "gate" used by Fisher Body when welding the body panels into a Body Assembly. Think of a fixturing jig. It is probable that the 2nd digit represented the fixture and the 1st digit represented the shift (1st or 2nd shift). (edit note, I think I had this backwards, so I changed it) Similar coding used on the Pontiac Plant Data Plates except that had a lot more "gates" for each Model Series and built the entire line up so something like 60 different "gates" will show up, Fremont had somewhere around 5 IIRC and only built the A body. Identifying the "gate" helped with QC if it was discovered that there was a fit up problem with the Body Assembly during Final Assembly. Knowing the "gate" allowed them to trace the problem back within Fisher Body. In '64, this code was embossed on the Data Plate at Fremont with the rest of the codes. For some reason, I think it was stamped on the Plate in '65 presumably after the Data Plate went on the firewall. |
#63
HOLY MOLY there is no greater treasure than this!
1: Absolute coolest car ever EVER made. Like cooler than an A/C Cobra. Like cooler than A Ferarri GTO. I mean the greatest automobile ever made! 2: The options! (Call me weird, but I would love a '65 GTO convert that was originally tri power and automatic...but that is off topic) 3: IT IS A TRUE TIME CAPSULE! I would take your car over three totally restored '65 convertibles, Hurst wheels and gobs of options regardless!! This car gives me the chills! Holy crap, this should be front page news!!!!!!!!!
1964 GTO 4 spd Fremont project car! 1960 Ventura Hardtop, Dad's oldie! 1962 Olds Dynamic 88 Hardtop, original 330 Horse 394 1965 Le Mans Convertible 326HO 1965 GTO 4 speed Convertible 1964 Olds 442 real! 1930 Model A Coupe (current project) 1927 T Roadster traditional style Hot Rod All of these cars are heaps...but I like them! |
#64
First pic = The amazing GTO in this thread Second pic = Another Fremont 65
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. Last edited by 60sstuff; 06-17-2013 at 08:46 PM. |
#65
[QUOTE=RAII 4-speed;4951762]
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
#66
K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
#67
Thanks for the clarification. John V - I believe the distinction here is that RPO A49 was the retractable seat belts (front only), which the original owner ordered. Since these cars did not come with rear belts then the original owner had the dealer install the rear belts (only). My car has retractable front belts and (as far as I can tell) does not have rear belts. K
#68
K
#69
12A build week.
So apparently the order paperwork sat in the que from July to December; the car was built in the December timeframe and shipped (relatively immediately) after completion. K
#70
The original owner told me that he indeed DID order the car in July of 1964 and with the 45 day strike there was a back log to make these cars and that is why he did not get his car till the first week of December. |
#72
here is a picture of the firewall, as you can see, there is a red x marked on the firewall with a crayon. I assume it is an inspectors mark...Your thoughts?
Also, there are a series of numbers punched into the firewall in fact there are 2 sets of them anyone know what they are for? THANK YOU in advance. Last edited by RAII 4-speed; 06-18-2013 at 09:01 AM. Reason: added picture |
#73
We normally will cover the cars on the final line with plastic/visqueen during extended downtime but cars that are stuck in paint or in the primer dip tank can get messed up. K
#74
Regarding the numbers: can you determine what the digits are? I'm wondering if it is some kind of build sequence number, but it could also be a part number/date code for that individual part (cowl panel). K
#75
The original owner of this car is truly a hero in my eyes. To have kept a car like this one in about as good a condition as you could hope for, is darn near a miracle. The second amazing thing is that this was a factory assembled car that wasn't built to last much more than 5-10 years, yet has made it 48 years, and everything still works, and looks pretty good.
#77
Fwiw, below is the trim tag off my Fremont built '65. Car was delivered in Sept. '64. Original, #'s matching block (EUN matches Protect-o Plate) is coded late July '64.
69 Judge, SURVIVOR, Carousel Red/Parchment, RAIII, 4-sp, 63k orig. miles, unrestored, #'s match 65 GTO, SURVIVOR, Tri-Power, 4-sp, 79k orig. miles, Capri Gold, orig. paint, top, interior, #'s match 70 GTO Conv, 400, at, A/C, Atoll Blue/Sandlewood/White top, all #'s match 2015 Challenger R/T Plus, hemi, Sublime |
#78
Keith, thanks for correcting me on the gate/shift order. I had it that way at first, but Sloan66 mentioned he had a 23 on a '66, figured there is no 3rd shift so wound up confusing myself. Can't explain a 23 on a '66, but you are correct about the '64s & '65s from Fremont. My own is coded 1-1 so couldn't figure it out from that.
And yes, there was NOT a rear seat belt factory option in '64 or '65, just the Dealer Accessory Packages. RAII mentioned the Owner had the Dealer add the rear belts, so that would be accurate. In '64, the Model Year started with two Front Seat Belt options, standard without retractors and custom with retractors. The standard belts were coded A20 at Fremont on the Data Plate. At KC & Pontiac, the standard belt accessory code was 5Z. Pontiac continued to show 5Z on the late year Data Plates even though that was now a standard feature (references had long indicated 5Z was seat belt delete but this was wrong). The only time the Pontiac Plant didn't code the 5Z after Dec was when the custom belts were ordered, code was 5W or when the Seat Belt Delete option was ordered, code was 5O. Obviously, there was NOT a seat belt delete option until the belts were made standard equipment in Jan, so early in '64, the lack of either a 5Z or 5W code meant no seat belts since they were only installed as optional equipment. But from Jan on, the 5Z code is very common on Pontiac Plant Data Plates in '64 once the standard belts were made part of the base equipment. At Fremont in '64, it seems that it was a bit more hit or miss after Dec. Some late year cars built with standard belts were coded A20 on the Data Plate, some were not but still got built with the base content standard belts. Early year at Fremont, lack of A20 or A49 code meant no seat belts installed. My own early '64 was built without seat belts, so no A20 or A49 on the Data Plate. I have never seen a '64 Fremont build with the Seat Belt Delete option, the UPC was A48. I assume A48 would have been coded on the Data Plate if it was ordered with Seat Belt Delete, but I've yet to see one with that factory credit option. Not sure about '65, I don't think the standard belts were coded on any Data Plate for '65, so you will not see A20 (or 5Z at Pontiac or KC) for '65. Only the A49 (or 5W at Pontiac & KC) when ordered with the custom belts/retractors. The Seat Belt Delete option UPC reportedly was changed to A62 per Eric White's book. I can't vouch for that, never seen one. But I am skeptical since his book shows the Seat Belt Delete as A48 for '66. I doubt that they changed the UPC in '65 and reverted back in '66. JMO. The nos. stamped on the sheetmetal are identifiers for the individual metal stampings that make up the Body Assembly. I don't believe they were specific to the build, pretty sure they were generic to the piece parts. IIRC, they might generally indicate the stamping plant or the application for the part, or perhaps a p/n. There is also a date coding. You can find these stampings on many of the individual body panels on the car. There was a thread awhile back where this was discussed. Maybe somebody here remembers it and can provide the link. The date coding on the body panels is a way to detect whether panels have been replaced. Generally, all of the panel parts will have date codes from the same time frame. If a panel shows a "wrong" date, it can indicate that it had been replaced or even evidence of a "rebody". I don't think the nos. on the firewall have been very carefully researched. But it is unlikely that they would be very meaningful either. The owner waited an extraordinarily long time for his car to be built. Even with the strike. The national strike was settled by end of October but it is unknown when individual plants went back to work. According to Calif employment history, the strike ended Sun Nov 8 but I still don't know when Fremont resumed production. But if the dealer actually placed the order as soon as possible, there should have been time to build the GTO prior to when the strike began on Fri Sept 25th. You mentioned the Owner had to reenter the order after his bank refused to lend him what he needed. Isn't clear how quickly the Owner placed the 2nd order, but I wonder if the dealer dragged his feet if he thought the Owner might not secure financing? Otherwise, the dealer might have gotten the car built when production began in August. Generally, customer orders got priority, so even the fact that this GTO wasn't built until early Dec suggests it got low priority if Fremont began production in early Nov following the strike. Just to be clear, I am not questioning the Owner's account. But I'm thinking that there may have been aspects to the story that the Owner was never aware of going on "behind the scenes" that resulted in the build being delayed. He understood the strike to have lasted 45 days. Officially, I think the strike was considered to be 38 days. But Fremont may have restarted production a week after the national strike was settled/ratified and production restarted at some of the plants on Mon Nov 2. If Fremont restarted Nov 9, that would have made it 45 days. And that corresponds with the Cali employment history record of the GM strike ending Nov 8. Plenty of cars were built before the strike, dealers had a significant supply of cars available. '65 production got underway on Mon Aug. 24 so production was blowing and going prior to the strike and new '65s weren't allowed to be sold until on or about Sept. 24, the traditional opening day 30 day wait period to allow all dealers to build inventory. If the GTO wasn't built in the month prior to the strike, but the order had been entered when PMD first started accepting '65 orders, the Owner was either unlucky or some other circumstance caused the order to be delayed. Maybe the Owner was aware of other circumstances about the wait that you haven't shared yet. I apologize for my speculations if they are off-track. I see your post where the Owner mentions there was a backlog of orders entered in anticipation of the strike. That is certainly valid. Just seems to me Warren-Vivaldi would have wanted to have the GTO which was already "sold" vs. inventory builds so from a "priority" standpoint, I would have expected the GTO to get built sooner than later. Just speculating that the dealer may have had his own reasons to back burner the GTO order. This is just the kinda stuff that fascinates me. That is the reason I've posted all this. You have acquired a very cool car in large part because it has a pretty interesting story associated with it and also because it remains in such exceptional survivor condition. Most of the above is just to add a little historical context. |
#79
Another point to note. Your Hardtop is Body No. 490 and a 9B Time Built code. As popular as the Lemans Hardtop was, that is a paltry no. if they had been building them for 2 weeks already. Perhaps Fremont was cranking out Chevy's to build there inventory prior to the strike and the Tempests were few and far between? If Pontiac was sucking hind tit at the start of production at Fremont, that may have accounted for why RAII 4-speed's GTO got pushed back. Would be interesting to learn the highest Lemans convert Body No. prior to the strike. May have been less than 200. |
#80
I just took some more pics of the GTO and thought I would share them.
let me know your thoughts. Thanks |
