SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 09-17-2017, 02:53 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Torino bearing is 3.150 OD yours should be 2.835?
Old 09-17-2017, 03:38 PM
Originally Posted by charlie66 View Post
Torino might be the same as mustang no?
This might help you guys:
https://www.jalopyjournal.com/forum/...earing.340971/
Ford Axle Bearing Housing End is based on Axle Bearing Size (Outer Diameter).
Old 09-17-2017, 05:19 PM
charlie66's Avatar
Looks like you are correct.
Here's where im measuring from.
You can press your bearing on this axle as long as the ID is the same ..
ID:	463735   Click image for larger version
My Half AN Injun.....
Old 09-17-2017, 05:21 PM
charlie66's Avatar
Thank you Tom....
Old 09-19-2017, 06:19 PM
ponjohn's Avatar
I cannot use them.... quote from Moser "Yes there are big ford bearings for 31 spline axles but no they cannot be used with an axle that was made for small bearing the bearing seats are not the same and location of the bearing on the axle is not the same"
Old 09-19-2017, 08:35 PM
charlie66's Avatar
Ok at least we all learned something from this .. Thanks for looking..
Old 09-19-2017, 08:39 PM
I originally ordered my 9" housing from Jim Butler with the "Big Ford Bearing Housing ends. I later decided to install the Explorer Rear Disc Brake Kit, It uses a Torino Bearing housing. Axles and Big Ford Bearing axles fit the Torino ends perfectly.
So to me that says that the Small Bearing 31 spline axles are unique to that housing.
Learn something new every day. Thanks ponjohn and Charlie.
Tom v.
Old 09-19-2017, 08:57 PM
charlie66's Avatar
I guess there talking about the location (where the bearing sits/ends up after pressing it on) from the bearing to the axle flange is further or closer.. ??
Old 09-20-2017, 09:28 AM
ponjohn's Avatar
Probably because of the housing end offset.
Old 09-20-2017, 09:43 AM
charlie66's Avatar
You would think you could put a spacer under the bearing to adjust that. If you had to go the other way you could machine the axle back maybe ? Who knows...
Old 12-23-2017, 10:25 PM
charlie66's Avatar
bump
Old 07-17-2018, 08:11 AM
charlie66's Avatar
bump
Old 07-13-2020, 08:53 AM
charlie66's Avatar
These were hardly used . Very good axles...
Old 07-13-2020, 04:14 PM
RAIV55 RAIV55 is offline
PM sent
Monty Frerichs
B&M Machine
Box Elder SD
yes!
Tom V
Old 07-13-2020, 04:45 PM
charlie66's Avatar
Originally Posted by RAIV55 View Post
PM sent
Returned
charlie66's Avatar
yes!
Tom V
Thanks Tom
  #38
Old 07-25-2020, 01:54 PM
charlie66's Avatar
SOLD
