Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 05-04-2020, 03:59 PM
tom s tom s is offline
Default Pontiac RA V tunnel port DS1200 heads and sheetmetal intake for sale
I just had these heads set up for a upcoming project that has taken a small turn.They are factory developmental 303 heads with 60cc chambers.They have been pressure tested and have had a complete rebuild with everything new.They are setup for a hyd roller cam with 150 on the seats and good for 660 lift.I will include all the removed pieces except for MAYBE on E valve and one spring seat.The machine shop is looking for them.I need to get $7900 for the package plus fedex shipping from 90814.You can PM or call or text me at 5622430570.Phone is on from 7 too 7 west coast time.Feel free to call with questions or other pics.Tom
ID:	539136   Click image for larger version
ID:	539137   Click image for larger version
ID:	539138   Click image for larger version
ID:	539139   Click image for larger version
Old 05-04-2020, 04:04 PM
more
ID:	539141   Click image for larger version
ID:	539142   Click image for larger version
ID:	539143   Click image for larger version
ID:	539144   Click image for larger version
Old 05-04-2020, 04:07 PM
even more
ID:	539146   Click image for larger version
ID:	539147   Click image for larger version
Old 05-10-2020, 11:52 AM
TTT
Old 05-23-2020, 05:11 PM
Still avail!Tom
Old 06-14-2020, 07:44 AM
pontiacjeff pontiacjeff is offline
These would be badass on the 326 short deck I'm building. Sadly, way out of my budget.
Jeff Ianitello
Old 06-14-2020, 12:58 PM
Too big of valves anyway!Needs at least 4in bore.Tom
Old 06-14-2020, 12:59 PM
What block are you going to use?Tom
Old 06-14-2020, 03:00 PM
Its a 301T block, 4bolt mains (7/16 outer studs), building a block girdle for it. Filling it up to the bottom of the freeze plugs. Going to be 4.030". Using a 316 forged crank, 3.25 stroke, that was welded up for 3" mains. Eagle 6.250 HRJ rods, superlight Icon pistons. Solid flat cam, RA4-ish specs on a 112, roller rockers, stud girdles. Right now have a set of 48s that have been ported. Dont know what they flow, prob 240-250cfm. Cut down TQII with runner extensions added in the plenum, plenum divider, 1" divided (or open) spacer, 750 Edelbrock
Jeff Ianitello
Old 06-14-2020, 03:34 PM
326 (331), 7000rpm street engine, 4sp, 4.11 gears, 77 Astre Formula.
Jeff Ianitello
Old 06-14-2020, 03:50 PM
They would work with the 301 bore but still tight.Are you on board with the hybrid head gaskets from Joe?Are they welding up the thrust also?Tom
Old 06-14-2020, 04:12 PM
spacer on block side?Tom
Old 06-14-2020, 04:47 PM
The thrust was welded up. This crank is beautiful. I have not had the rods turned down yet, but will keep it 3.25" stroke.
I am using Program billet caps and will machine the cap for the 400 thrust bearing. The cap (and the crank) will keep the upper bearing from moving. Not planning to use a bearing spacer.
I have heard about the (Cometic?) head gaskets, but don't know who has them. Do you have contact info? Thanks.
Jeff Ianitello
Old 06-14-2020, 05:14 PM
They are not Cometic,they are SEC.I think they have to be bought from Joe.I have my set.PM me a cell number and will send you a pic.Tom
SCE!
Old 07-08-2020, 07:29 PM
Still looking for a home!Tom
Old 08-03-2020, 12:17 PM
New price.$7500 but the used valves,springs and retainers are no long avail.Tom
Old 10-26-2020, 01:29 PM
TTT
Old 11-16-2020, 07:06 PM
TTT
Old 12-12-2020, 09:25 PM
$7250 without the carb!Tom
