Old 07-08-2020, 09:44 AM
ejgoat ejgoat is offline
Default Gto rear wire ribbon clips
I need 3 clips that go on the rear tail light ribbon, there,s two on each end does anyone have three for sale,
Old 07-08-2020, 11:29 AM
tempest1964's Avatar
I probably don’t have it, but can you post a photo of the clip you need? Might help to find it.
Old 07-08-2020, 02:51 PM
Don,t seem to be able to post a picture of must be dumb
Old 07-08-2020, 04:06 PM
It’s kind of tricky. If you can text it to someone, maybe they can help. PM me if you want
Old 07-09-2020, 02:44 PM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is offline
Are these the clips you need? Attached to the floor and hold the ribbon wire (pic 2) in place. Ames sells them, that’s where I got mine.
ID:	544621   Click image for larger version
Old 07-09-2020, 04:30 PM
Skip Fix's Avatar
Skip Fix Skip Fix is online now
So do repop wiring harnesses use a ribbon?
Skip Fix
Old 07-09-2020, 06:23 PM
Rich-Tripower's Avatar
I don't think anyone reproduces the flat ribbon wire that runs from the fuse box to the rear kick up behind the rear seat.
Old 07-09-2020, 06:49 PM
You’re correct Rich, the ‘64 ribbon cable is a one year only and no one makes it. The 65-67 has different end plugs and it is reproduced. I think Buick and Olds a-bodies used the same ribbon cable as Pontiac in ‘64. Can’t speak for Chevies.
Old 07-13-2020, 10:24 AM
ZnbOlds455's Avatar
ZnbOlds455 ZnbOlds455 is offline
Default Ribbon cable
I've seen the ribbon on OPGI. I'm working on a '65 and have it on my wish list for later.
Old 07-13-2020, 06:57 PM
Skip Fix's Avatar
Mine would be a 65.
Skip Fix
Old 07-13-2020, 09:03 PM
ZnbOlds455's Avatar
Default Hold Down Strap
Here’s the hold down. They also have the front/rear ribbon harness called the intermediate harness.
