Old 07-22-2020, 03:21 PM
6t5gto 6t5gto is offline
Default radio to dash spacing
Has anyone else had an issue with the right side radio knob bezel not sitting flush to the ribbed dash plate?
Old 07-25-2020, 07:53 PM
HALFWAY's Avatar
HALFWAY HALFWAY is offline
My 64 radio right radio knob bezel also exhibits the same. I never really noticed it and I have had the radio out a couple times. It's not much but it's there. Here is a couple pictures. If your gap is larger then I am not sure what the issue would be.
ID:	545778   Click image for larger version
I don't always cross thread the bolt - but when I do I run that bitch in with an impact until it's tight!
Old 07-25-2020, 10:22 PM
Dick Boneske's Avatar
Can't you fix that by adjusting the nut behind the sheet metal to hold the radio further forward? That's what those nuts are intended for.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 07-26-2020, 12:48 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
1965 dash knobs.
Two different thickness.
Chris.
ID:	545806   Click image for larger version
ID:	545807   Click image for larger version
ID:	545808   Click image for larger version
ID:	545809   Click image for larger version
Old 08-02-2020, 03:55 PM
60sstuff's Avatar
The radio is designed to be sucked tight against the steel dash structure, so the radio surround bezel is even / flush with the trim plate.
There is also a “Z” shape bracket under the radio to support the weight.
There are different designs through the years on this bracket as seen below.
CT
ID:	546293   Click image for larger version
ID:	546294   Click image for larger version
ID:	546295   Click image for larger version
Old 08-13-2020, 09:09 AM
I realized the reason my right side knob was sticking out after I looked at 60sstuff pictures. My knobs are from Ames and the right side knob does not have the center of the knob big enough for the nut so my knob is sitting on top of the nut which pushes the knob outward. I guess the fix would be to drill out the center of the knob slightly bigger than the nut.
