Old 07-22-2020, 08:46 PM
OG68 OG68 is online now
Default What are They?
Have a pair of unmarked brackets in a parts box. Can anyone identify?
ID:	545566   Click image for larger version
2007 Cadillac SRX
Old 07-22-2020, 08:58 PM
How big is the hole?
Possibly hold down/holders for ignition wire clips on valve covers?
Old 07-23-2020, 11:32 AM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
They kind of look like firewall brackets that hold wiring harness in place. Correction. The mounting hole is too big to be those.
Rethinking the one on the left looks like a broken off tab for securing tranny dipstick tube to back of motor.
Old 07-23-2020, 12:55 PM
Thanks guys but I have the a 3 Spd manual, and the plug wire holders and firewall clamps are accounted for.
The hole is 1/2" diameter
2007 Cadillac SRX
Old 07-23-2020, 03:28 PM
1lms 1lms is offline
Look like wire holders for reverse light wiring on trans
Old 07-23-2020, 10:35 PM
Ill have to check the Assembly Manual. Or perhaps the speedo cable to motor mount for the Dearborn trans?
2007 Cadillac SRX
Old 07-24-2020, 03:12 AM
I've been all over my car and not saying everything is still there as built but I've never seen those that I can recall.
Old 07-24-2020, 07:34 AM
Half-Inch Stud's Avatar
Never seen them.
But if i did, they were clearcoat and had melted black rubber on the blank ends.
Old 07-24-2020, 08:06 AM
With that big of a hole, I'd say it went on the bolts that bolt the engine mount. They may have been used to keep the wire(s) for starter away from exhaust.
(brackets basically to run starter wires above mount?)
Some later years had something like that, not sure on 67.
Old 07-24-2020, 10:46 AM
Should have said 1968 for above.
Old 07-24-2020, 02:21 PM
I looked again at the assembly manual particularly around the motor / trans mount but didn't see anything. But, since its for the 69 it won't show how the wiring for the 68 back up lamp switch is run. For the time being I'm going to assume these clips / brackets, due to the size of the hole, attach to the bell housing bolts and route the back up lamp wiring down the driver side of the bell housing.
Thanks to all.
2007 Cadillac SRX
Thread Tools
Display Modes
