Old 07-27-2020, 02:07 PM
na1969 na1969 is offline
Default 1969 GTO
air conditioning duct don't open help
Old 07-27-2020, 02:20 PM
Scott Thelander's Avatar
how about a little less info ??
The Following User Says Thank You to Scott Thelander For This Useful Post:
Old 07-27-2020, 09:40 PM
Drag Star Le Mans's Avatar
It's vacuum operated, more than likely a leak? Or the vacuum control valve, or...
Could be ten different things.
DragStarLeMans
Old 07-28-2020, 12:53 AM
getmygoat's Avatar
Get a hand held vacuum pump from ebay or HF for $10. Plumb to the vacuum actuator and see if it opens. if not, you found the problem. If it does, then confirm intake manifold vacuum properly plumbed to the system. Or maybe reverse the order of those steps.
