Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 12-29-2020, 02:22 PM
71 T/A 71 T/A is offline
Default Looking for 7028268 Quadrajet
Anyone have a good core or rebuilt 7028268 carb?
Old 12-29-2020, 04:45 PM
69FIREBIRD76MM's Avatar
https://www.ebay.com/itm/1968-Pontia...cAAOSwkeFeqe~W
Old 12-29-2020, 05:49 PM
I saw that one. It's missing too many parts and is a tad rusty.
My 68 GTO is a June 68 car so would prefer one before that date.
Old 12-29-2020, 11:05 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
For what its worth.
I had the privilege of meeting Cliff R (the carb expert) this year and was in his shop twice for some carb kits and a rebuild.
He told me when you see a sticker like on that carb it has MOST likely had the seat (needle & seat) drilled out and one pressed in making it un-rebuildable!
So be careful!
Old 12-30-2020, 11:06 AM
Yeah, stay away from those parts store stickered 'Reconditioned' carbs. They look great but they block off various passages and sometimes mix and match parts from different carbs. In fact, I have an '8262' that fits that description. It's basically the same carb as the 8268. I use it for parts now.
I later switched to a '74 carb. Much better design than the '68 as I have learned. If you're not going for absolute numbers correct, even the '69 carb would be a better choice.
Old 12-30-2020, 11:30 AM
Ken, will double check, believe I have a nice core 7028268.
Old 12-30-2020, 12:01 PM
RACERDAVE RACERDAVE is offline
Default CARB
HI, I HAVE A VERY NICE 7028268 ALL ORIGINAL CARB AND A MATCHING INTAKE. PM. ME IF YOU WANT TO SEE PICS. I REMOVED THESE FROM MY 68 GTO CONVERTIBLE ABOUT 30 YEARS AGO. LET ME KNOW IF YOU ARE INTERESTED IN EITHER, OR BOTH..VERY CLEAN AND ORIGINAL...
Old 01-04-2021, 08:43 PM
Still need one. It's ok without a date.
Old 01-04-2021, 10:18 PM
blubiu65 blubiu65 is offline
I have a 7028262 1968 auto carb. I know not quite the number your looking for but close.
Old 01-05-2021, 09:55 AM
As far as I know, it's the same carb and when I've looked, it's for the same application in '68. All that last number means is 'even number= auto tranny'.
I'm not one of the 'numbers experts' here though... I can just tell you that the '8262' is what was on my car when I got it and my manuals showed it as correct for a '68 400 automatic.
Old 01-05-2021, 10:37 AM
TB1's Avatar
TB1 TB1 is offline
found in another thread, I have swapped some carb parts with him in the past and all went well.
http://forums.maxperformanceinc.com/...d.php?t=837495
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt
The Following User Says Thank You to TB1 For This Useful Post:
Old 01-06-2021, 12:40 AM
3goats's Avatar
3goats 3goats is offline
Have you found a carb ? I have a few 8268's and 9268's. and a 0268 I need to check dates and let you know
Old 01-06-2021, 02:30 PM
I found one. Thanks.
