Old 07-17-2020, 12:36 PM
DM3 DM3 is offline
Default Fuel Tank Sending Unit Wire
Can someone tell me where the sending unit wire enters the car and is routed?
DM3
IG: #67MoparBird (Follow my rebuild)
1967 Firebird 400
Appeared on Gearz, Season 16, Episode 1, Segment 'What Are You Working On?'
Old 07-17-2020, 12:46 PM
leeklm's Avatar
leeklm leeklm is offline
Usually comes across top of fuel tank, and enters the car through the trunk floor near the taillight panel. Normally a brown wire, it is routed to the taillight harness that travels through the rear seat panel under the backseat and along the drivers side floor to the dash harness.
Sent from my SM-G965U using Tapatalk
Old 07-17-2020, 01:00 PM
JLMounce JLMounce is offline
Yup, it's a tan wire that travels on top of the tank and enters through the same passage as the rear license plate light. Attaches via a connector at the base of the trunk support where it joins the tail lamp and mid-car harness.
-Jason
1969 Pontiac Firebird
Old 07-17-2020, 02:09 PM
JimFB400HO JimFB400HO is offline
Here's the routing in the '68 for the two wires (black license plate light and tan sender) emerging from the from the harness connector. I don't know if the '67 or '69 were different.
Name:	Sender and Plate light wires.jpg
Old 07-18-2020, 08:04 AM
DM3 DM3 is offline
Thank you, I will check it out today.
1967 Firebird 400
