spacer length 80 amp static alternator set up ??
Hey everybody looking for some info ! Trying to put together my front drive set up for my 71 TA as my car has AC and rear defrost it came with the 80 amp static set up . I purchased a complete set up minus the big spacer that goes on the belt tensioner bracket approx 3.5 inch long and the little one that goes between the top bracket and the alternator . If anyone out there in Pontiac land knows how long these spacers should be would be greatly appreciated
Ken |
Hopefully this helps some
Sent from my iPhone using Tapatalk |
In the restoration sticky up top, there are threads you can search from NJ Steve .I think he has those Dims. Search his threads with search tool
I've got that idler pulley set up if you need one.
Thanks Dave
Thanks for the info I have the same pic in my service manual but no H/W break down . Any chance you have the one for AC compressor brackets with H/W ??? Was going to try and fit it up and figure out the spacers but if you had one would save me a lot of messing around any help would be killer
Ken |
looking for 80 spacers , 11 ,28 and 31 . were can i get these or can i make my own
I MAY have #11...need to look I'll be in the garage tomorrow....
I kinda remember seeing something in my box like this ...any idea on length ????
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
All those were with the big bag of 80 amp brackets I sold you a while back. To make your own, youll need some dimensions from a set .
yes thanks i just found them
