Old 10-27-2020, 04:41 PM
NYGTO's Avatar
NYGTO NYGTO is offline
Default Column Mounted Tachometer
Guys, the 1965 GTO I recently bought has an aftermarket tach from "day 2" installed on the steering column. It doesn't have a transmitter and runs straight off the distributor,
The brand isn't visible on the old unit but I'd like to change it to a different vintage tach like a Radatron or Dixco. Can anyone tell me which brand is the same simple hook-up or how you might have set up yours.
Thanks in advance
Old 10-27-2020, 05:26 PM
Pictures of what you have would narrow it down from a crap shoot.
Radatron and Dixco were the 2 least likely to be used back then. Sun and Autometer were the 2 of choice by serious racers.
On a crap shoot, without seeing it, I'm going to say Autometer because their name is in small print at the bottom of the dial. Kinda difficult to see.
Old 10-27-2020, 06:29 PM
Keith Seymore's Avatar
I believe there is a re-pop vintage appearing Sun tach on the market now that does not require the transmitter box.
http://67-72chevytrucks.com/vboard/s...&highlight=Sun
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
Old 10-27-2020, 07:23 PM
Bill Hanlon's Avatar
Sun SuperTach II and its knockoffs are 4 wire (power, ground, points or coil - and dash lamp), 270 degree sweep and come with a steering column mount.
Bosch and others make a 90 degree sweep dash or column mount tach with a similar 4 wire connection.
No sending units for any modern (late 60s or newer) tach.
Old 10-27-2020, 09:25 PM
RAC was a real popular brand back in the 1960's. I used them on my cars. You could buy them at department stores, speed shops and auto parts stores.
Old 10-28-2020, 10:30 AM
NYGTO's Avatar
Here is a picture of the 55 year old unit. That's cardboard wedged in the glass to keep it from moving around.
Old 10-28-2020, 11:34 AM
That looks real familiar, I just can't think of the brand right now. It also looks like the lower portion of the lens was painted by someone, not the maker. That might explain the cardboard holding the lens.
This might be a Chevy piece. People would take factory Pontiac tachs and vacuum gauges, paint over the Pontiac name and use them in other cars.
Old 10-28-2020, 11:44 AM
69hardtop 69hardtop is offline
Glad to see it has the standard issue radiator clamp holding it to the column.......
Old 10-28-2020, 12:26 PM
So maybe something like https://www.classicindustries.com/pr...EaAmXxEALw_wcB
Old 10-28-2020, 03:42 PM
NYGTO's Avatar
Thank you guys for responding. I'll check out your ideas and look into a vintage Sun FZ tach or a new vintage looking one. Chief, the tach lens wasn't painted but when I move it around there is still no name to be found. Thanks again.
Old 10-28-2020, 05:14 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
That kind of looks like a Stewart Warner. Here's a pic of my Sun.
Old 10-28-2020, 08:37 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
Originally Posted by Bill Hanlon View Post
I bought this reproduction and installed it in my old 65. Easy 4 wire installation.
Old 10-28-2020, 10:10 PM
Rich-Tripower's Avatar
FWIW, here is a vintage Drag Fast tach I have in my wagon.
Old 12-17-2020, 07:43 PM
tallrandyb's Avatar
tallrandyb tallrandyb is offline
Super Tach II for the win! Had one in for 5 years, no rally gauges.
Sent from my iPad using Tapatalk
Old 12-17-2020, 10:46 PM
OG68 OG68 is offline
This is my Stewart Warner tach from 1965. Dad pulled it from a 64 Fairlane when he traded it in and installed it under the dash of the GTO in 68. I pulled it out 15 years later when I installed a factory in dash tach. Since then it's been in a 65 Chevy pickup, 64 Catalina, and a 70 El Camino. El Camino has been sold so the SW is going back into the GTO and I'm installing a clock in place of the in-dash tach. The SW is still accurate after 55 years. Sending unit goes back on the firewall.
ID:	556367   Click image for larger version
2007 Cadillac SRX
Old 12-17-2020, 11:27 PM
This one's been sitting here for 56 years:
'63 Grand Prix
The Following User Says Thank You to Keith Seymore For This Useful Post:
