what is this part
looks like a sending unit on the pass side . i also have one on the drivers side
I'll have the first guess that its a water temperature sensor, John L.
Sent from my SM-T585 using Tapatalk
have this on the driver side
Now that 2nd photo looks like an oil pressure sensor, just my guess , I'm sure I will be corrected if wrong
John L. Sent from my SM-T585 using Tapatalk
The first Pic is a water temp switch, for a warning light or emission devices. Maybe TCC since this is a 72.
The second Pic is a water temp sender. This is for the gauge in the dash.
I built it one piece at a time and it cost me more than a dime. |
It is for the Transmission controlled spark(TCS) system. Are you going to use that system? You will have a plug in your harness for it.
not sure yet is that for a auto tranny . i have converted to 4 speed
Both would have it from the factory. the component that changes would only be at the trans.
ok so the factory installed both ,but only used one depending on the car you ordered
This would be an all or none deal for me. Clay |
Automatic had a switch that would trip at 38mph, a manual had a switch for 4th gear. Being you switched to a 4spd. Does the 4spd you got have a switch in the side cover where the shift levers attach?
will check and let u know
is this what you mean
Yes, the harness should connect to that switch. That switch should be grounded unless the transmission is placed into 4th gear.
TCS, Temp controlled Spark. You do NOT want or need this working on your car. More things to go wrong and it was not designed to work with fuel that burns hotter, and advances that are more advanced than stock.
should i just plug the hole in the block/head then . or install the sending unit and not hook it up
Saying that, the engine will run better with it disconnected. Disconnecting it from any electrical connection will turn the system off. Last edited by necdb3; 11-02-2020 at 10:57 AM. |
3 but only 2 prongs used
