Old 12-03-2010, 11:38 AM
Andre's Avatar
Andre Andre is offline
I would change it out. That car is too nice to have a detraction like that. To keep things rolling, you could go with a pair of repo mesh, and get the originals worked over, and replace later. Is the engine out of the car?
Old 12-03-2010, 11:47 AM
geeteeohguy's Avatar
What a beautiful car. LOVE the color. Yeah, fix the grille. You can probably remove it and bend it back into shape. Hit a deer with my '67 convert about 15-20 years ago, and it bent the grille mesh on that same side. R&R'd the grille, worked it a little, and re-installed it. Came out perfect. That mesh and surround is workable...just be patient.
Old 12-03-2010, 12:07 PM
Gator67's Avatar
Gator67 Gator67 is offline
Well, I'm glad I'm not being too picky. I seem to recall that the grilles are pretty fragile...I remember snapping off a tab or two trying to straighten one out back in the day--but I had a lot less patience back then. So, how are the repo pieces? I've read that the mesh is smaller, but I've never compared them to originals side by side (in fact, I'm not certain the grilles on the car are originals or repos).
The engine hasn't been assembled yet. It's such a tease going to the shop and seeing the finished block and heads sitting in bags and the boxes with my rotating assembly and cam, etc. on the shelves....
ID:	226758   Click image for larger version
Old 12-19-2010, 10:01 AM
Gator67's Avatar
Here are some pics of the #s WS engine. It will look stock when it's done, but it's a 462 with a H roller setup.
ID:	228399   Click image for larger version
ID:	228400   Click image for larger version
Old 12-19-2010, 11:35 AM
goatmanmitch's Avatar
goatmanmitch goatmanmitch is offline
Man, that is one good lookin' engine bay.
Mitch Kunath
Old 12-19-2010, 12:40 PM
oldgoat16's Avatar
oldgoat16 oldgoat16 is offline
Post 67 convertible
Gator67, that is one perfect 67! The color combo is really sharp, keep up the good work!!
Old 12-19-2010, 04:00 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
Car looks nice. It'll look great when finished.
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
Old 01-04-2011, 10:47 AM
Gator67's Avatar
Diamond Back redlines (Firestone Firehawk Indy 500) on their way to get mounted on some original HURST wheels. These wheels are one of the few things on the car I restored myself (albeit under the guidance of a very active member of this board who's initials are TJ, whom I can't thank enough for all his help). I'll be delivering these to the shop later in the week. Can't wait to see what they look like on the car.
Name:	HURST wheels.jpg
Old 01-04-2011, 10:51 AM
shawn e.'s Avatar
shawn e. shawn e. is offline
This thread has me drooling, Nice Car!
Shawn
"Don't let fatigue make a coward of you."
Old 01-04-2011, 03:18 PM
All I can say is in a thread like this, pics tell a thousand words.
Old 01-08-2011, 11:25 AM
Gator67's Avatar
Dash turned out nice. The rally gauges are a little faded, but they cleaned up really well. I'd like to find a header control head with better chrome.
Old 01-09-2011, 10:10 AM
Hey that dash looks great. Did you do it yourself?
Old 01-09-2011, 11:26 AM
Gator67's Avatar
Thanks Paul. Heck no, the dash was done by Steve Dietz at his shop here in FL. He does great work.
Old 01-21-2011, 11:06 AM
Gator67's Avatar
Here's an update on progress. As you can see from the first photo, the grille situation has been...straightened out (thanks Paul).
I got to hear the engine run, and I'm very pleased--more aggressive and louder than the previous stock set-up, but not over-the-top. I wanted the engine to look fairly stock, but as shown in photo 2, spacers were needed to clear the roller rockers and poly nuts. Less noticeable than tall aftermarket covers.
Because I plan on driving it a lot, I went with a rear sway bar.
The top was supposed to go on this week, but the top installer noted several issues with the components that came with the kit (pad, well liner, window--not from our host BTW), and so the shop ordered a new top and kit (this time from our host).
Name:	new grille.jpg
ID:	231562   Click image for larger version
ID:	231563   Click image for larger version
Name:	rear sway bar.jpg
Old 01-21-2011, 02:02 PM
Gator, that looks REALLY nice. You're putting on a white top, I presume?
Jeff
Old 01-21-2011, 02:15 PM
Old Goat 67's Avatar
Gator,
That really looks good!
I wish I was that far along, you make me envious.
Just one thing, can't tell for sure, but in your engine picture, is the top radiator hose too high so as to trap an air bubble?
Charles
Old 01-21-2011, 02:47 PM
Andre's Avatar
Good move to let the top guy order the top himself. I used him for my '64 convertible and I supplied the top. Guess what... the top had one of the bow sleeves installed incorrectly. I could have had him start over, but opted to move forward as is. 8 years later, I had mostly forgotten about it till you mentioned your situation.
Good move on the valve cover spacers. That is quite unnoticeable and definitely the way to go instead of aftermarket.
  #38
Old 01-21-2011, 02:54 PM
Gator67's Avatar
Andre, Steve told me that there was something wrong with just about everything in the top kit. The pads were the universal type with incorrect covering, the rear window side flaps were top color instead of black like they are supposed to be, the rear window zipper was incorrect, and the well liner was wrong material and had snaps on it which are incorrect.
Jeff, yes the top will be white. Non-original, but it will help keep this non-A/C cool and I prefer it against the light green.
Charles, the radiator hose does look high in the photo, not so much in other photos. I'll check it out next time I'm down there.
Thanks for the compliments!
  #39
Old 01-30-2011, 06:58 PM
luvmygto's Avatar
luvmygto luvmygto is offline
Wondering if I should try to get a straighter grill or just live with it.
Looks like it's winking to me
  #40
Old 01-31-2011, 02:59 PM
Gator67's Avatar
To me it looked more like a classic case of asymmetric ptosis...I guess I'm a just a glass-half-empty kinda guy
