Old 10-26-2019, 01:19 PM
694.1 694.1 is offline
Default 1967 Firebird rear axle assy. SE WI. $250 3.08 open
I ran this for several summers, the seals were replaced, bearings replaced as needed, seems like I even had the pinion out to check those bearings.
No axles but I have spare backing plates around. This will fit a 68 & 69 but is designed for mono leaf springs. It has been sealed up so no worries there.
3.08 open gears.
ID:	523009   Click image for larger version
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 03-19-2020, 11:41 AM
Bump
7th Firebird
57 Starchief
Old 10-18-2020, 10:25 PM
Bump
7th Firebird
57 Starchief
Old 10-19-2020, 04:09 PM
patox's Avatar
patox patox is online now
Send a message via MSN to patox
Would you sell me the gears?
No need for the rear.. just the gear
Let me know
Old 10-19-2020, 06:42 PM
Disassemble a smooth & quiet rear end with great bearings & seals? You can do that for $250
7th Firebird
57 Starchief
Old 10-19-2020, 08:06 PM
patox's Avatar
If you ship it to me for 250 ill gladly do!
Just need the gears.. and shipping is an issue.
Let me know if you change your mind
