Old 10-24-2020, 01:00 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
My "06D" Fremont car has a block cast date of F027 and EUN is 656945.
Name:	Data Plate - Trim Tag.jpg
ID:	552170   Click image for larger version
ID:	552171   Click image for larger version
Old 10-24-2020, 01:11 PM
428ho4spd's Avatar
Originally Posted by Longs View Post
My '67 GTO was built in Pontiac, invoice date is June 29, 1967, date on the block is June 23, 1967. Engine Unit Number is 703042.
Longs... I'm curious if your late built '67 also has the '68 style accelerator cable bracket on the manifold?
ID:	552174   Click image for larger version
Old 10-25-2020, 11:14 AM
Longs's Avatar
Longs Longs is offline
I don't know what distinguishes the 68 style from the earlier style, here's a picture. It has the same part number as in your photo. What is different between the 68 style and the earlier style?
Looking at my picture, I really need to spend some time cleaning the carb!
Old 10-25-2020, 11:56 AM
428ho4spd's Avatar
That's it! Part number "9792069" stamped just below the cable like in my photo above. Also, it has a "tang" for clamping the power brake booster hose to it for '68 and up Pontiacs like my other photo shows. I can't see the "tang" on yours as it's covered up by your plug wire loom bracket which by the way is mounted incorrectly if you'd like to fix that. I'll post a photo for you of how it should be mounted. It mounts at the rear bolt hole in the head just above the freeze plug.
LOL... that's how my carb looked before rebuilding it, actually worse!
Thanks for confirming another "late '67 build" bracket usage.
Old 10-25-2020, 12:16 PM
I recently sold what was left of a 1970 Trans Am. I had dismantled the car years ago and only kept the firewall forward because everything else was pretty rusty. The build dates didn't make a lot of sense because the motor was all dated March but the cowl tag was showing July. It was a WV car with 70K original miles, auto with no a/c. The block had no VIN stamped in it at all. My guess is the original engine had problems, so the car was pulled off the line so a replacement YZ could be installed, and they didn't stamp the VIN.
I also had a 1971 YE with no VIN as well.
Old 10-25-2020, 12:53 PM
Longs's Avatar
.... I can't see the "tang" on yours as it's covered up by your plug wire loom bracket which by the way is mounted incorrectly if you'd like to fix that. I'll post a photo for you of how it should be mounted. It mounts at the rear bolt hole in the head just above the freeze plug.
I see what you mean on the wire loom bracket, I had to go out and look at the head, at some point I'll relocate it to the right hole.
My original intake isn't on the car (I still have it), probably 35 years ago I noticed a small vertical crack at the base of the carb, and rather than attempting to get it welded, I replaced it with another '67 intake that I got from a junkyard, it's dated April 1967. The engine was also rebuilt over 30 years ago, so the wire loom bracket could have been incorrectly installed back at that time too.
In the context of the "date evaluation" that this post's about, my intake is dated June 6, 1967 so it was cast 17 days before my block.
Old 10-28-2020, 08:22 PM
Ducks Goat's Avatar
Ducks Goat Ducks Goat is offline
Just for the sake of sharing here's a pic of my June Pontiac plant built GTO's bracket.
1999 WS6 Formula, 1 of 175
1967 GTO Linden Green 4 spd, A/C, survivor
1967 Lemans convt
1967 Firebird 400 bench seat, deluxe interior, auto
1965 GTO 462, KRE unported D-port heads, Bullet 234/244 cam, th400, tight 10" converter, 3.73 gears, 87 octane, 3440 lbs. empty,1.59 60ft, 7.159@95.33 (1/8), a real daily driver, been totaled, rolled 3 times, hit a tree airborne.
1961 Catalina 2 door htp
1960 Ventura 4 door htp wife's car
1960 B'ville 2 door htp
1960 Catalina Wagon wife's car too
Old 10-28-2020, 09:13 PM
428ho4spd's Avatar
And we have another! Thanks for sharing that.
