8 lugs
has any one run 8 lugs with there dis brake convrison and where did you get them thanks 65 cat
I believe what is commonly done is to take a set of eight lug rear drums (which slip over the rear axle flanges and studs) and machine off the bulk of the drum leaving you with a disk that can be slipped over the lugs on the front. After that, the eight-lug rims are bolted on as normal. Perhaps someone running this type of setup will chime in.
Sent from my iPhone using Tapatalk |
