Pop Noise in steering
When steering my '72 Trans Am at very low speed, the steering/suspension will occasionally "pop". I don't notice any other issues but I'm curious what to look for. Thx!
Dan |
upper control arm bushings and or lost alignment shims
in just one direction of turning ? turning into the drive way ? |
Have you greased it ....Ever?
Yes, like turning in the driveway. It’s only happened a few times and I’m not sure if it’s while turning in the same direction.
Stabilizer link hole wore oblong lower control arm....????
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
Check for a cracked lower control arm just inside the lower ball joint. It seems to be a thing especially after they've been replaced and pressed in. I haven't experienced it but do a search on this site... it's happened more than a few times.
"I know just enough to keep me here, but not enough to get me out" |
