Old 10-17-2020, 09:43 PM
tjs72lemans tjs72lemans is offline
Default Hood to fender rubber bumpers
I tried to pry the rubber bumpers in the inner lip of fender, but successfully destroyed the first one. It severed the pointed angle portion I was trying to push into slot with a screw driver. Now I'm thinking of just using weather strip adhesive to adhere to inner side of fender for hood to wedge against. How do most of you get this rubber pushed into slot of fender?
Old 10-18-2020, 04:55 AM
Scott Thelander's Avatar
wd40
Old 10-18-2020, 07:59 PM
Thanks Scott, I'll try that.
Old 10-18-2020, 08:17 PM
Tomslemans67 Tomslemans67 is offline
I have put them in boiling hot water for few minutes to soften them up. Tom
Old 10-18-2020, 10:19 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
I use a fine layer of white lithium grease too. That always seems to work.
Eric "Todd" Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
'67 Tempest Wagon (428/TH400/2.56 posi)
Deuteronomy 8:3
Old 10-20-2020, 08:56 PM
I'm going to wait until this weekend and turn my furnace up warmer. The rubber will be more forgiving. This MN weather stinks!!
Old 11-10-2020, 06:31 PM
I actually had to trim them quite a bit to persuade them in the slots of fenders.
Old 11-12-2020, 10:45 PM
1965gp 1965gp is offline
I trimmed mine as well
