Old 09-07-2020, 09:48 PM
62 bv 62 bv is offline
Default 8 lugs
has any one run 8 lugs with there dis brake convrison and where did you get them thanks 65 cat
Old 09-07-2020, 10:44 PM
ben3843100 ben3843100 is offline
I believe what is commonly done is to take a set of eight lug rear drums (which slip over the rear axle flanges and studs) and machine off the bulk of the drum leaving you with a disk that can be slipped over the lugs on the front. After that, the eight-lug rims are bolted on as normal. Perhaps someone running this type of setup will chime in.
