1964 alternator part no
I am finishing my 1964 Pontiac 2+2 Convertible with factory air. What is the correct alternator gm number for the car?
Thanks Jim |
My 64 MPC shows 1100633, all except TI, less pulley.
Practicing social distancing for 65+ years |
I show 1100681 as the alternator?
(55 amp for Circ-L-Aire Conditioning)
believe I have a '64 usage '"681",
will ck alt stock for its date code & get back on here late tonight.
633 is the service replacement number for 681.
From 66 Parts
Cool doc.
Any idea if the replacement alternator had the replacement # on it or the original #?
I would really expect the service number to be stamped otherwise there would be no need for a new number.
I found 681 in the service manual. wrong one on car so will look for correct one. All other numbers match like they should - car only has 41000 miles
Nice Cat. Love those 8 lugs
If you understand how to use it, the Cross Reference Chart in the MPC will help you identify the OE p/n.
The Service p/n was for the bare alternator. It carried a specific p/n, you were expected to reuse your original pulley. A single Service p/n could therefore service multiple OE alternators. The OE alternators were supplied by Delco WITH the pulley so they carried their own specific p/ns and were application specific but were not serviced that way.. The OE alternator p/n for your application is listed in a few places. The Shop Manual may be correct but there is a '64 SCN (Issue No. 2 IIRC) that lists the OE alt p/ns. It revised certain info in the Shop Manual, not sure the alt p/ns were affected. Johnta1 might be able to help you out by posting a copy of the SCN page. |
They use the 10 DN alt with the separate voltage regulator..
I have one for a '64 with air. The number is 1100681. PM if you want pictures or more info.
