Old 10-10-2020, 11:32 AM
punkin punkin is offline
Default sub-frame bushings
Hello all,
This may seem like a dumb question but...I've been doing some refresh work on my 68 firebird. While underneath I noticed that the body/sub-frame bushing/mounts are all cracked and getting flattened out.
If I were to replace them, are there things I should be worried about such as body panels coming out of alignment?
One more question on this matter. Years ago I put in some hooker super-comp headers and they made contact with the floor. I had to apply some heat to them and bend them about a 1/4" to get the needed clearance. I'm now going with a new motor and a set of Doug's Headers. If I replace the body/sub-frame bushings, is there a chance that this would also improve the spacing between the floor and the headers?
Again, sorry if this is a stupid question. It just seems to me that if I add fresh bushings there could be a whole series of unexpected that might happen.
Thanks,
1968 Firebird
IAIIa 522
340 E-heads
Northwind with XFlow TBI
4L80E
3.50:1 Rear
Old 10-10-2020, 12:33 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Usually body panels do not move as long as fender bolts are all tight. To do the core support-at least on my second gens I loosen those bolts and the next ones back and put the jack under the core support to move it up enough to slide the old ones out and new ones in.
Skip Fix
Old 10-10-2020, 12:46 PM
leeklm's Avatar
leeklm leeklm is offline
I am guessing you will get a little more body lift with new bushings, especially with poly, which won't have as much squish as rubber
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
Old 10-10-2020, 12:53 PM
Sirrotica's Avatar
Sirrotica Sirrotica is online now
FWIW, I used the Moroso aluminum bushings decades ago in my second gen 73 T/A, Everything bolted up and never had to worry about the subframe shifting as the rubber compressed. I also had a 76 T/A with OEM bushings that was like a rubber band when you jacked it up.
If I was ever to own another subframe car it would have something besides the OEM bushings.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 10-11-2020, 04:50 PM
Great...thanks everyone. I'm going to jump in and do it. Figure with a new front suspension and shocks all around why not tighten up the body/frame while I'm at it.
Thanks!
1968 Firebird
IAIIa 522
340 E-heads
4L80E
3.50:1 Rear
