Fixing Dents in 1970 GTO Endura Bumper
Hello,
Fixed a pretty big dent that lifted up the bottom of Endura Bumper with a Jack,chain and a hook. It's is still off a bit on left side, on top and bottom. Any advice on getting it to line up with the grille better. Was using hammer and small sledge, but don't want to damage it. Is heating up a bad idea? Also is it okay to use a little bondo or do you recommend something else? Please see attached pics. Thanks in Advance. |
Bondo won't flex. You need something like 3M 5896.
thanks for the quick reply will get the 3M 5896 look sperfect, and ideas for straightening a little more? mini sledge??
No heat.
If the area is tweaked it is the steel frame inside that is bent and you will need much pounding with a sledge and block of wood or bottle jack to get it moved back. Any damage to the rubber can be fixed with the flex repair epoxy. I recommend you read some threads about best practices for Endura repair, especially concerning epoxy primer. SPI is recommended by many.
Michael Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done... |
By the way, the full weight of my truck on that bowed rail did not move it even an inch. I eventually got the bow out by cutting partway through the rail, bending it where I wanted it and welding the cut. The second method, with the chain, did get the nose pulled out about where I wanted it.
Greg Reid Palmetto, Georgia |
. dstryr, since 1986 . |
Thread Tools | |
Display Modes | |
